wierd noise after transmisson change :(
Old Oct 1, 2011 | 01:46 PM
cadwiese's Avatar
Default wierd noise after transmisson change :(
so i changed my ls trans with another ls trans and now when i let the clutch out in neutral or any gear it makes a crazy noise.....also i dont have any gears
plz help
Old Oct 1, 2011 | 02:10 PM
92lxsleeper's Avatar
Default Re: wierd noise after transmisson change :(
clutch installed backwards? input shaft bearing shot? input shaft damaged? axles seated properly? theres too many things that could be wrong here, could you post a video?
Old Oct 1, 2011 | 02:16 PM
tlarimer's Avatar
Sounds like clutch release bearing slid off of clutch release fork. Did you reuse all your old components, meaning just trans replacement, or did you use replacement trans clutch release fork, clutch release bearing, pressure plate, clutch disc, etc?
Old Oct 1, 2011 | 02:29 PM
he says he doesnt have any gears, so i would think its not the release bearing, only because he would not be able to get into gear because the fork is not able to release the clutch by itself.
Old Oct 1, 2011 | 02:40 PM
Evoinboost's Avatar
X2
Old Oct 1, 2011 | 02:46 PM
tlarimer's Avatar
I read that wrong, I read it a not going into gear and noise in neutral.
It could be any number of things.
OP, was this a known good trans that you swapped in?
Old Oct 1, 2011 | 04:38 PM
cadwiese's Avatar
i was told it was a good trans and i reused my clutch, release bearing, and fork from my old trans that worked fine.
ty for the responses
Old Oct 1, 2011 | 04:42 PM
Former User's Avatar
Sounds the input shaft bearing is shot.
Old Oct 1, 2011 | 04:45 PM
tlarimer's Avatar
^+1
cadwiese's Avatar
by chance is that input shaft bearing hard to replace?
Old Oct 1, 2011 | 05:06 PM
gorilla_joe's Avatar
just what im going through now on mine. input shaft bearing shot makes a horrible noise when the clutch is let out. but im able to get into all my gears and drive just sounds like poo poo.
Old Oct 2, 2011 | 05:02 PM
cadwiese's Avatar
SO I CHANGED THE TRAMSMISSION BAD TO THE OLD ONE AND NOW IT WONT GO INTO ANY GEAR BUT IT DOESNT MAKE ANY WIERD NOISES
Old Oct 2, 2011 | 05:12 PM
tlarimer's Avatar
Filled with correct MTF fluid?
Clutch disc installed correctly?
Hydraulics bled and functioning correctly?
If yes to the above, I would start looking at the pressure plate as the culprit
Old Oct 2, 2011 | 05:37 PM
cadwiese's Avatar
YES TO QUESTIONS AND DAMN IT I DONT WANT TO DEAL WITH THIS PROBLEM RIGHT NOW
Old Oct 2, 2011 | 05:40 PM
tlarimer's Avatar
The problem your having now is exactly the problem I had a year ago, would go into all gears with vehicle off, start car and depress clutch pedal, wont go into any gear. I tried everything, hydraulics, Genuine honda MTF, new clutch fork, in the end it ended up being a bad pressure plate, which was brand new from NAPA, got a Genuine Honda pressure plate, problem solved.
Old Oct 3, 2011 | 05:42 PM
cadwiese's Avatar
k also some more info when i put the key in the ignition now and put it to the on position and let the fuel pump prime....the speedo needle jumps to about 40 mph and falls back down??? ive never seen that happen before but idk
ty for any help
Old Oct 3, 2011 | 08:39 PM
cadwiese's Avatar
bump
Old Oct 8, 2011 | 12:44 PM
cadwiese's Avatar
anyone?
Old Oct 8, 2011 | 05:25 PM
cadwiese's Avatar
well i got the trans working again my dumb *** didn't put the drive shaft in all the way
now to fix the cel
Old Oct 9, 2011 | 08:57 PM
cadwiese's Avatar
ok now the car seems to be ok but i still have the speedo woerd needle jumping issue....any ideas?
Old Oct 10, 2011 | 07:12 PM
cadwiese's Avatar
and the battery is dying
any info would be nice
Old Oct 10, 2011 | 07:25 PM
92dxbeast's Avatar
New to ht but I have the same issue with my speedo. It's time for a new one mine starts to work after about 20 mph then when I go up to 80 it gets stuck and the thing is way off
Solstic
Jun 13, 2012 11:34 AM
wessieball
Feb 25, 2009 12:44 PM
H.crx-si
Jul 31, 2004 06:27 PM
Ditdogs
Apr 17, 2004 10:57 PM
ludelvr
Sep 28, 2003 11:02 AM
