1992 Prelude Headlight Problem
Old Oct 1, 2011 | 12:38 PM
PinoyDelS0l's Avatar
Default 1992 Prelude Headlight Problem
Alright so I picked up a 92 prelude from my brother in law to use for the winter and to commute to work. This car is riced the hell out with halo headlights and what not. So I ordered new headlights to bring the car back to stock and when I went to turn the headlights on I noticed the passenger side headlight is very dim. And this problem is a continuing problem since the halo headlights were on the car before. But anyways, when I turn the low beams on the driver side headlight output is very strong and correct, but the passenger side headlight output is very dim. So then I tried turning the high beams on and the driver side headlight works correct but the passenger headlight turns completely off, which I mean no low/high on at all. So now im stuck and I need help. I never mess with electrical wiring so this is not my field I ever play in haha. If anyone has any ideas please let me know! Thanks!
Old Oct 1, 2011 | 01:02 PM
Default Re: 1992 Prelude Headlight Problem
Ok I just figured out my own problem, the right headlight fuse was blown so it was drawing power from the left headlight which caused it to be so dim. I changed he fuse and now both headlights are working in correct order. Something so small, can really think you have a short or a bad ground some where lol. Thanks.
sealocean
Honda Civic (2001 - 2005)
Mar 21, 2012 06:33 PM
hotaccord243
May 29, 2008 01:00 PM
STYLiNxCHiQ_DA9
May 27, 2006 09:02 AM
WHTEG
Mar 5, 2004 03:56 AM
