HELP!!!! both fogs and one hid is out in my 93 da
as the title says both the fogs and one hid is out and checked all the wires and they seem fine. checked the fuses and they all are fine. the bulb for the hid appears to be okay. can someone please give me some advice onto where to go from there cause im completely stumped.
Check the ground connections..
swap your non working hid bulb to the working side. (just to check if the HID ballast/bulb is working)..
for the Foglights. Check your switch. Or if your using the OEM loom/switch. check the connection to the fuse box.. If you dont see the problem there then try removing the Positive(+) wire of the foglight and tap it to the Positive post of your battery.(Just to check if there is no problem with your foglight.) If that Didnt work, Check the BULB LOL!
