1990 honda accord ex 2.2l f22a transmission delay
Old Sep 28, 2011 | 12:16 PM
jdmcertified909's Avatar
Default 1990 honda accord ex 2.2l f22a transmission delay
as I was diagnosing the car to give my client the list of things I would recommend to change. So heres the problem. I put the auto tranny in d4 didnt engage. I had to give it gas then it engaged. Jumped the plug no codes. He said its been like that since he got it. Solenoida seem ok. Ohms seem fine. What else can it be? What are the solenoinds ohms suppose to be maybe they are bad
Old Sep 28, 2011 | 12:28 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1990 honda accord ex 2.2l f22a transmission delay
Is it full of fluid? Did you check the solenoid screens? Does it do this in the other gears as well? D3 D2 D1?
Old Sep 28, 2011 | 04:53 PM
[QUOTE=MAD_MIKE;46095293]Is it full of fluid? Did you check the solenoid screens? Does it do this in the other gears as well? D3 D2
Well I took off only the top solenoids they look clean. I put them back and decided to give it a go and gear engages right away now. and it only did it on d4 if I put it on d3 d2 and 1st they would engage right away before removing the solenoids. So it only did it on d4
mrdon213
Transmission & Drivetrain
May 24, 2017 09:45 PM
laloquera916
Mar 14, 2011 01:35 PM
greenejo
Dec 16, 2008 06:12 PM
josebaldy
Jun 21, 2006 01:25 PM
jayp4757
Apr 14, 2006 08:47 PM
