97 Civic B18 Swap... ISO Turbo.
Old Sep 26, 2011 | 10:35 PM
cooch-wizard's Avatar
Default 97 Civic B18 Swap... ISO Turbo.
I own a 1997 honda civic hatchback.
I ordered a full turbo kit which came with a t3/t4 turbo.
its too big to use it on my manifold and engine block.
sooo...
I am iso a t25, 15 or 16g, or what else?
help me out guys!
I have $154 paypal left to play with.
and i dont want something that needs work done to it.
Im hoping to install the engine in a week or so.
advice would be helpful!
i just missed out on a garett t25 that doesnt need any work for 150...
someone bought it before i did.
sucks.
i might take pictures of the installation if you guys think i should!
thanks.
Old Sep 27, 2011 | 03:10 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 97 Civic B18 Swap... ISO Turbo.
What? How is it "too big"? Physically? Or too much for your horsepower needs? It's a kit. How is it too big? Doesn't sound like a good kit. Ebay?
$154? You must be taking about an Ebay turbo. Can't help u with that. Don't think anyone could.
And you know you've got the tune, upgraded fuel system, clutch, wideband/gauges and other things to deal with right? Way more than the $154 you have in your pocket.
Old Sep 27, 2011 | 04:36 AM
Wrona's Avatar
wow another kid that thinks that they can just slap ebay parts on their car and go from there really really stupid
Old Sep 27, 2011 | 04:42 AM
ReDHaTcHyGuy's Avatar
yea how is it to big? if you bought a kit it should bolt right up
Old Sep 27, 2011 | 09:18 AM
the turbo was a giant .63 ar...
i want a .43 or w/e t25.
i have three two thousand dollars in parts thank you.
and i spent a grand for my engine.
i have everything i need for my engine swap and turbo assembly...
except my current turbo will not fit.
all i need is a t25, 15g, or 16g.
lmk where i can find one that doesnt need a repair kit for cheap.
thank you.
Old Sep 27, 2011 | 09:21 AM
The Grumpiest
So why in the hell did you order a kit with a turbo in it you didn't want? Doesn't sound very smart to me. For $154 your only option is Ebay. How much you spent isn't a factor. That you spent it poorly is. Cal the people you ordered your kit from and see if they can work something out.
Old Sep 27, 2011 | 12:42 PM
i bought the turbo to use it man...
the issue is that when i put the turbo on the manifold and put the manifold on the engine...
it rubs on the engine.
its toooooo big.
sooo.
i need a smaller turbo.
you understand now?
im still iso t25.
i just found a t28 garett for 150.
im prob gonna buy it tonight.
thanks for nothing guys.
Old Sep 27, 2011 | 05:10 PM
blackeg's Avatar
This thread should be locked. What a sour attitude. on someone who is asking for information handouts
Old Sep 27, 2011 | 05:20 PM
D16SiHatch's Avatar
i agree completely
Old Sep 27, 2011 | 05:22 PM
TheShodan's Avatar
Moderator
This definitely needs to be locked. He doesn't understand that almost any "kit" is not a "bolt on affair". He has a LOT to learn.
Old Sep 27, 2011 | 06:42 PM
your retarded.
i have a chipped ecu, 450 cc injectors, turbonectics t3/t4 turbo kit, and a b18c1 engine... etc...
I stated i have everything i needed other than a smaller turbo.
was it really necessary to talk trash instead of helping me out?
epic fail.
Old Sep 27, 2011 | 06:57 PM
hoffmanb16's Avatar
It's because you said you only have 160 to spend so they assume your going ebay turbo and get all in a tiff, it's very lame I agree.
How bad does the current turbo hit? If it just rubs you might be able to use a thicker gasket in between the block and the turbo manni to give it a little more distance.
Old Sep 28, 2011 | 02:52 AM
The Grumpiest
Originally Posted by cooch-wizard
your retarded.
epic fail.
There's no helping you. You have a built engine and you're looking for a Cheap turbo that you could've run on a stock block. All because you planned **** poorly.
Old Sep 28, 2011 | 06:17 AM
Wrona's Avatar
i like how he says hes going to buy the garett for 150 but has only 160 to spend but has not mentioned how hes going to tune it...
kid your attitude is horrible you get on a forum where alot of people buy ebay turbo kits and thats what it sounded like youre doing is buying an ebay turbo kit you mention nothing about a TUNE your clutch all you mentioned was 450CC injectors and a chipped ECU with that your car will run maybe a month and die and than you'll realize oh yeah im the retard not those guys they were trying to help me duh seriously loose the temper
Old Sep 28, 2011 | 07:14 AM
spoolinlude's Avatar
I live under a rock
thank you.
What turbo manifold did you buy that a t3/t4 won't fit on a B18? Thats like the most generic turbo setup of all time..... .63 is a small a/r, completely standard for a basic turbo setup. A 1.12 T4 housing would of been giant.
BTW, what the hell does "three two thousand dollars in parts" mean? If you're saying you have 3k in parts, good for you. I have 3k in my fuel system if you want to start throwing dollar amounts around thinking you're spending serious coin.
I hate it when people flame someone who doesn't know what they're doing or talking about, because we've all been there. There was a point when each of us were 'noobs'. Basically your lack of research lead to buying parts that aren't compatible with each other. You came on here and asked a stupid question then tried to act like you know what you're talking about, when clearly you don't or you wouldn't of had this problem in the first place. I realize you're frustrated, most people on this website are pretty ruthless when it comes to newbies, but you're only going to dig yourself a deeper hole if you try to act like a know it all, when your problem is entirely the fault of your own doing.
Old Sep 28, 2011 | 03:06 PM
yea that turbo is just fine, you dont need a smaller one... did you try bolting the turbo on the oposite way? where is it rubbing
Old Sep 28, 2011 | 03:11 PM
Dee's Avatar
Dee
He probably needs to notch the wedding on the block if the manifold is one of the designs from the late 90's to '03 range. Pics would have helped but he is obviously too dumb to post something like that.
Old Sep 29, 2011 | 01:25 PM
or maybe the turbo needs clocked alittle
Old Sep 29, 2011 | 02:41 PM
Hidenplanvew's Avatar
I bet this guy dosent know what he is doing... A t25 is going to be a waste above like 6K on a gsr... It will actually slow it down...
You might as well get a Generic garrett T3 turbo off a saab for 90 bucks
huevoriox
Oct 11, 2018 03:24 AM
me3333
Jul 17, 2016 08:15 PM
nightz-riderz
Oct 24, 2010 11:24 PM
bkmc24
Jun 21, 2006 12:19 PM
ferby
16
Jul 3, 2005 01:43 PM
