what does it take to change TDC sensor
Old Sep 26, 2011 | 12:55 PM
clubworkz's Avatar
Default what does it take to change TDC sensor
Autozone did a code scan on my girlfriends 96 ex and said the top dead center sensor was out. They didn't have "that" part.
Old Sep 26, 2011 | 12:59 PM
Former User's Avatar
Default Re: what does it take to change crankshaft sensor
Car? Engine?
The TDC is inside the distributor. However, this code can be caused not only by a bad TDC sensor, but also by a bad TDC sensor wire or even a bad ECU. Resistance test the TDC sensor (should be 350-700 Ohms) and test the two TDC sensor wires for a short or open. If the TDC sensor is bad, you generally need to replace the distributor housing.
Lavid2002
14
Jul 3, 2012 01:46 PM
ed1le
Jul 17, 2006 09:00 AM
quik89
Nov 30, 2003 06:43 PM
solman74
Sep 14, 2003 04:27 PM
fast-rex
Jan 27, 2003 03:06 PM
