D16y8 swap trouble
Old Sep 26, 2011 | 07:03 AM
VXvtec's Avatar
Default D16y8 swap trouble
Okay, here is the story. We swapped a d16y8 into my 93 civic eg hatchback and everything was a simple plug and play. However, now it just won't start for **** no more. At first, it started and cranked up. Now, it's just not starting no more. Well, what happened was that we were testing all of the spark plugs, right? Then, I started pulling out the spark plug wires to test out the car an then all of the sudden when I got to spark plug wire #3 the car just died! Now it won't start up for **** now! Any advice would greatly be appreciated! Also, the car sounds funny when we were able to start it up. It was lagging really bad and had a CEL on, too, shiet!
Old Sep 26, 2011 | 07:20 AM
98civdx's Avatar
Master Detailer
Default Re: D16y8 swap trouble
Dig you pull the cel?
test the coil.
Old Sep 26, 2011 | 07:45 AM
VXvtec's Avatar
test the coil.
Will i be able to use my original ignition coil then? If so, I'm changing it. Also, the car revved up really slow and I have no idea why it was that way. Well for the check engine light I have no idea how to even check it....
Old Sep 26, 2011 | 11:49 AM
kiko1973's Avatar
Oky you swap motors & now you have a D16y8 motor on car 93 hatch. First off all you will need to swap out your injectors, disturbutor and ecu (P28). everything else is a plug and play. Witch I assume you did cuz the car crank up. You are coming of a OBD2 to OBD1. If you had power the first time of the swap you are in gud hands. Does the car try's to turn over or just dead but has power.
Old Sep 26, 2011 | 12:56 PM
Former User's Avatar
Unplugging spark plug wires while the engine is running is one of the best ways to blow the coil inside the distributor.
Old Sep 26, 2011 | 07:20 PM
VXvtec's Avatar
The car wants to start up, however, it wont crank up because I'm assuming it has to do with me taking out the spark plug wire on cylinder on #3. After that, it has been a mess! I'm thinking the dizzy got fried or the ignition coil is dead. Any advice would greatly be appreciated.
Old Sep 26, 2011 | 07:23 PM
VXvtec's Avatar
LOL, damn! Okay, so would I be able to use my stock ignition coil from my 92-95 honda civic, or do I have to god damn spend $60-80 to get a new ignition coil? So, do you think it's the ignition coil or the distributor that is dead because I tested it out and the wires and spark plugs are not getting any sparks at all. However, when we tested my wires on my cousin's d16y8 my wires had power and it started. I'm thinking either my ignition coil is dead or I fried my dizzy!
Old Sep 26, 2011 | 07:26 PM
98civdx's Avatar
Master Detailer
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Sep 26, 2011 | 07:38 PM
The FAQs sticky has a diagram that tells you how to test the coil.
Old Sep 26, 2011 | 08:04 PM
VXvtec's Avatar
So, I was wandering if any of you guys knew how to convert my 5 wire oxygen sensor to a 4 wire oxygen sensor? Any advice would greatly be appreciated!
Old Sep 26, 2011 | 09:55 PM
apexi_rsx's Avatar
i have a ignition coil if interested and why not just buy a used 4 wire o2 sensor for 30 bux? it will plug and play and get u going for the mean time. i have both laying around
Old Sep 27, 2011 | 06:24 PM
VXvtec's Avatar
Thanks you, I won't need any of your parts because I already have a four wire o2 sensor and my old ignition coil out of my d15z1 worked, great! Anyway, I figured out what was wrong with the car, lol. It was exactly is what I was thinking... I was the god damn rotor, dizzy cap, and ignition coil, ***! Now I just need a ecu and need to rewire my 5 wire o2 sensor to a 4 wire o2 sensor.. Anyone knows how to rewire it? Any help would greatly be appreciated! D16Y8 semi-complete...
Old Sep 27, 2011 | 06:44 PM
apexi_rsx's Avatar
http://hondaswap.com/swap-articles/v...or-info-13759/ just 2 seconds of googling i found this hope it helps
Old Sep 27, 2011 | 06:55 PM
altfuelneeded's Avatar
sounds simple but did you check all of your fuses could have just blown one
Old Sep 30, 2011 | 08:37 PM
VXvtec's Avatar
ty for the info..
VXvtec's Avatar
I should probably do that too, lol.
Old Oct 1, 2011 | 05:23 AM
N/A's Avatar
N/A
Purpose Built
What???! Why? Did you have any idea how hard it is to find those factory widebands?
Old Oct 1, 2011 | 05:39 PM
Sol-Power's Avatar
Did you happen to paint the y8 engine block before you put it in? Check the thermostat ground wire that is part of the harness for contact and corrosion. I had the same problem and it turned out thats what it was.
Try sanding the contact points on the thermostat housing and on the ground wire with a heavy grit sand paper, like 180 grit or even 220.
hondaxnoob
11
Apr 27, 2013 12:41 PM
Cameron60
Feb 19, 2009 10:22 PM
em1_fox
Oct 28, 2007 12:11 PM
AznBlueBoy
Sep 8, 2006 08:21 PM
[626]95-GSR
Feb 14, 2002 03:11 PM
