Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
R18 Turbo Kit
Old Sep 25, 2011 | 07:42 PM
ToeDrag's Avatar
Default R18 Turbo Kit
How much power can a stock R18 hold?
Old Sep 26, 2011 | 05:28 AM
Willie Mack's Avatar
Default Re: R18 Turbo Kit
That remains to be seen. There was one that was trying for 300whp. Sadly, this was before Flashpro and the tuning software was shady at best. That car ended up with issues. Couple that with shitty mechanic work, and you have yourself a perfect storm. but now that the solution is out, I think things may run a lil smoother. Granted the block doesn't crack. I heard that was an issue with the R18.
Old Sep 26, 2011 | 03:46 PM
ToeDrag's Avatar
i have heard it was able to hold 320whp before changing the cams and the pistons, and they i started to hear that with anything over 10lbs of boost i will run into problems with the tranny!
Old Sep 27, 2011 | 07:51 PM
420Coupe's Avatar
320whp im not sure, as of right now i am one of the ones pushing the R18 the hardest currently at 276whp/249 wtq @ 9 psi on a 5857, what turbo you looking to run ? also i highly advise against anything above 300whp on stock internals. as my mounts are shot from 241 whp when i was tracking before i upgraded to more power. anything over 10lbs of boost and you need the 4bar map sensor from hondata specifically for the R18, have to call and order. Although right now i am doing a full upgrade and fully building the R18 full internals and all. CP piston makes the pistons for the R18 and Pauter makes the rods. Rest is all custom ordered from supertech and hypertech. Tranny holds up fine as well as stock clutch.
i would say stock R18 can hold 300 whp max
Old Oct 15, 2011 | 03:03 AM
chriskramer5's Avatar
wonder if the kits work on the 2012's
Old Oct 17, 2011 | 08:21 AM
420Coupe's Avatar
it should nothing changed except maybe ECU and flashpro might not be compatible. Just like how FP doesnt work for the new 2012 Si, although they are working around the clock to get it to work.
Old Oct 17, 2011 | 09:51 AM
It can. The only issue I see with it is the stock header. It's a cast in.
Old Oct 17, 2011 | 07:19 PM
420Coupe's Avatar
False. Its the exact same as previous R18s the header is a bolt on 4 bolts.
Old Oct 18, 2011 | 10:13 AM
Ok. So it's just the 2012 Si with the funky looking header connection?
Old Oct 18, 2011 | 12:39 PM
HRsi-dan's Avatar
I'm pretty sure the R18 has always had a cast-in manifold.
Old Oct 18, 2011 | 06:14 PM
thakid09's Avatar
1)Is anyone running the TSI kit? 2) Max boost on stock internals? ive read anywhere from 8-20 :s 3) Does anyone recommend head studs? 4) A solid aftermarket cluth is (brand name here). Thx
Old Oct 19, 2011 | 02:07 PM
420Coupe's Avatar
Clutch masters / Competition clutch. Max boost on stock internals depends the turbo, im assuming since the TSI kit its going to be a gt25 which i would say 14 psi, 16 psi pushing it, member blew at 16 psi on a hot day. if u can get the head studs why not.
2012 SI now has a plastic intake manifold and no vtec profile on the exhaust cam. but thats irrelevant the R18 SOHC remains the same.
Little update!
see in the picture only 1 exhaust outlet for the R18.
Old Mar 21, 2012 | 06:58 AM
shanedapaintrai's Avatar
Has anyone tried to open up the exhaust manifold so it can exhale better????
Old Sep 19, 2012 | 12:51 PM
brayden06's Avatar
just order tsi kit, but really just a newb any suggestions for the internalls of engine so i dont blow the thing sky high?
Old Sep 22, 2012 | 06:59 PM
Wik's Avatar
Wik
Perhaps I should put on my flame suit, but why are you looking at a turbo kit for your car. I don't want to get into purpose or intent, but non-si's were built for things other than raw power. Torque steer is no fun and the motors aren't built to handle boost. You're better off improving the handling and driving the car for its intended purpose.
Old Sep 23, 2012 | 09:27 AM
420Coupe's Avatar
Yes I have, call up 4Piston Racing
Old Oct 17, 2012 | 12:28 AM
h22boii's Avatar
Im running 15bs of boost on my stock internals from 4-6th gear, but i have the full race thrbo kit that has a garrett 3076r turbo
Old Oct 19, 2012 | 02:58 PM
lostdaytomorrow's Avatar
From a logical point of view, If you want power, best to go with a different platform.
Old Oct 22, 2012 | 05:49 AM
420Coupe's Avatar
You sir are an ignorant illiterate retard. This is the R18 not K20Z3. ******* read the tittle of the thread before you spew irrelevant information.
Old Jun 27, 2013 | 09:34 PM
divetony's Avatar
i have a 2012 Honda civic EX non SI, can anyone suggest to me on what turbo i could buy that will work on my car im looking for as close to a bolt on as i can get. your help would be amazing!!
Old Jul 1, 2013 | 08:39 PM
5G_Vtec's Avatar
Forced induction for the 2012+ R18 is currently useless without a proper tuning solution. Full-Race and Jackson Racing, however, has confirmed their 8th gen R18 setups to be compatible with the 9th gen.
Old Mar 28, 2024 | 04:46 PM
manny 3920's Avatar
Question man Im looking to turbo my r18 automatic what do I need besides the kit? Do I need new injectors and new pump ? Do I need to get a 4bar map? And do I really need a hondata flashpro Just trying to buy everything at once and no miss one thing TIA
Old Mar 28, 2024 | 08:05 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
If you don't buy a FlashPro, how do you intend to tune the engine ?
Old Jul 5, 2024 | 09:08 AM
OgRick's Avatar
Do you still run the R18?
mikkey1
May 29, 2008 03:56 AM
95 civic turbo_gsr
May 6, 2008 07:47 PM
Boostin_GSR
Dec 22, 2006 08:36 AM
tc85
Apr 5, 2006 01:04 PM
f22suzuka
Aug 3, 2003 06:15 PM
