Vents won't stop blowing hot air (96 civic). Need advices
Old Sep 25, 2011 | 01:14 PM
Pwnmeister's Avatar
Default Vents won't stop blowing hot air (96 civic). Need advices
For some reasons, my vents won't stop blowing hot air once the car reaches operating temperature. Even if I adjust the temperature all the way to cold.
So whenever I drive on the freeway, the vents won't stop blowing hot air and it gets really hot inside the car. I tried moving the temperature all the way to hot and the air becomes even hotter. Moving the temperature back to cold only makes the air a bit "warmer" but it's still hot air
I already made sure the wire thing attached to the back of the climate control is connected correctly.
Is it because my car has no A/C? I thought it would at least blow cool air from the outside even with no A/C.
I drive a 96 civic btw.
Old Sep 25, 2011 | 02:06 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Vents won't stop blowing hot air (96 civic). Need advices
Where do you think the air is coming from exactly?
Old Sep 25, 2011 | 02:09 PM
Pwnmeister's Avatar
Mostly towards the face from the front vents and the 2 vents by the side mirrors
Old Sep 25, 2011 | 02:20 PM
The Grumpiest
You misunderstand me. You don't have an issue. This is normal.
Old Sep 25, 2011 | 05:14 PM
virgineg6's Avatar
Does it blow air while you are just parked or only while you are moving?
Old Sep 25, 2011 | 05:21 PM
B16Power's Avatar
Does it blow in a clockwise direction or a counter clockwise direction because if you are unable to tell in might be a dalerod gone bad in the engine to cabin distributor which could in turn cause the major increase of hot air you are noticing.
Old Sep 25, 2011 | 05:39 PM
fonkernuckle's Avatar
So are you having air blowing in without the fan being on and with the recirc button engaged if so I would say your climate control is not working properly and since you have already checked to make sure the wire is still hooked up on the bottom, have you tried pushing it down there to see if it opens and closes properly with your hand and then compared to using the temp control.
You might need to replace climate control
Old Sep 25, 2011 | 08:08 PM
Former User's Avatar
There's a valve on one of the heater hoses on the firewall. It controls coolant flow through the heater core. Manually close the valve and then check the heater cable.
Old Sep 25, 2011 | 09:47 PM
TechM's Avatar
^+1
Check this valve first to make sure your heater control cable is closing the vent all the way
Old Sep 25, 2011 | 11:21 PM
Touek's Avatar
I have the same problem as you
Old Sep 26, 2011 | 04:38 AM
The Grumpiest
The way I read this was that the OP is expecting that went he wants to have air blow out of the vents and he sets the unit to a "cold" setting, with no A/C in the car, he is expecting the air to somehow still blow cool. Mainly because he says this
Originally Posted by Pwnmeister
Even if I adjust the temperature all the way to cold. I tried moving the temperature all the way to hot and the air becomes even hotter. Moving the temperature back to cold only makes the air a bit "warmer" but it's still hot air. I thought it would at least blow cool air from the outside even with no A/C.
Old Sep 26, 2011 | 10:35 AM
Pwnmeister's Avatar
So the air will always be hot no matter what if I have no A/C? I don't know if that's true which is why I started this tread.
Old Sep 26, 2011 | 10:38 AM
The Grumpiest
Ask yourself, where is the air vented from, exactly? When it gets cold outside then it'll blow cold air. The air, with no A/C, will be slightly warmer than the ambient temperature of the air outside.
Old Sep 26, 2011 | 10:49 AM
If the heater valve is closed all the way, then there's nothing you can do except install A/C.
Old Sep 26, 2011 | 10:53 AM
Pwnmeister's Avatar
okay I'll check that
Old Sep 27, 2011 | 08:13 AM
philly10psi's Avatar
theres an easy way to fix this...put ur vents on recirculate mode...u wont get any air from the vents u might get a lil bit coming from the floor but its not as bad...i had the same problem with my car...i have no ac system i took it off for my turbo
Lithel
Oct 3, 2023 12:51 AM
02CivicEXPhilly
Honda Civic (2001 - 2005)
Jul 1, 2008 04:54 AM
alscrx
10
Jan 3, 2008 06:57 PM
Canonm7
Jun 28, 2005 08:25 PM
