97 CX hatch/GSR swap - cut wire harness issues
Need some help from you guys...
Looking at a 97 CX hb with a 98 gsr engine and trans swap.
However owner says it was a hack wiring job causing some shorts bad running issues.
If I can get a good price on this vehicle, what is the best route to get it up and running?
All new wiring harness or just try to clean it up somehow. Owner says he used the civic cx harness and cutoff connectors he needed from the GSR engine harness.
What problems may I encounter or what should I look for when I check out the vehicle?
Any estimates on cost to get this in proper shape?
-gsr harness $ ?
- new ecu $?
- cx harness $?
Thanks would appreciate some help!
-gsr harness $ ?
- new ecu $?
- cx harness $?
You can use the CX harness but if its as bad as it sounds then you should get a 96-98 Civic EX harness. Then use a 96-98 P72 ECU and wire up the IABs on the intake manifold to the ECU.
i can't see the harness going for more then $100. I see them all the time for $50-60
For the ecu, who knows. I've seen them for $40, and over $200.
Are you planing to do any modifications to the engine?
Thanks I think he has the p72 in it from the gsr he took drivetrain from not for sure though yet... so I will most likely need a new harness, brake work, and vtec solenoid to get this running. I would get the ex harness just because it is Vtec wired correct?
Awesome that's not too bad of an investment to get a car running, you'll have to to keep an eye out for me for a nice looking harness! I was looking at oem gsr harnesses earlier and they seemed pricey but no need for that now~
Yes eventually not sure what he has done so far but i'd just make it breathe better first then think about cams and porting, itb's would be fun someday
http://cgi.ebay.com/ebaymotors/96-97...item27be6e3574
something like this? I assume it has to be a MT harness as well?
Can anybody link me to or show me pictures of wiring up the IABs?
Hopefully the guy just didn't know how to wire his swap and I can pick up a nice project that will be fixed in no time!
Any tips on what to look for as far as problem wise on the car since it has been sitting for a year and a half - think I should rent a compression tester ?
Mad-Mike
11
Jun 23, 2011 03:40 AM
redboost10
Feb 10, 2005 11:20 AM
Mischief_EG
15
Jun 15, 2004 07:56 PM
