LSD ? please help
I did a jdm b16a sir 1 swapp i got the y1tranny with lsd. when i turn corners it makes really loud noises and sounds like the axels are shot.
i have only driven the car once scence the swapp in fear that i would damage the tranny or snap an axle. i need advice before the swap the axles made no noise at all the car was quiet. i had a shop change the clutch because i had no time to. they put in regular motor oil. is that why it makes the horrable noises? the guy from hmo told me i needed special lsd tranny oil. will that solve the problem? will that make the car run fine? he recomended redline fully synthetic lsd manual tranny oil. will that make the noises go away?
sorry i posted this in the wronge section and it won;t let me erase it.
[Modified by bmcc72, 10:28 PM 10/4/2002]
i have only driven the car once scence the swapp in fear that i would damage the tranny or snap an axle. i need advice before the swap the axles made no noise at all the car was quiet. i had a shop change the clutch because i had no time to. they put in regular motor oil. is that why it makes the horrable noises? the guy from hmo told me i needed special lsd tranny oil. will that solve the problem? will that make the car run fine? he recomended redline fully synthetic lsd manual tranny oil. will that make the noises go away?sorry i posted this in the wronge section and it won;t let me erase it.
one^g
14
Nov 14, 2005 12:31 PM
