What is the best grease to use on a window regulator?
I'm removing the old grease and putting new grease on a used window regulator I bought.
I'm replacing the grease on the "scissor's" teeth and also the grease inside the window motor's gear box. I believe white lithium grease is supposed to be used for everything but the old grease doesn't look like white lithium grease.
So should I use white lithium grease for everything or are there other greases I should use?
Would white lithium grease be ok for the rubber o-ring seals in the gear box?
graveltravel2
11
Feb 21, 2007 03:43 AM
