K22a? PLEASE HELP
Old Sep 23, 2011 | 07:47 AM
Ericezy's Avatar
Default K22a? PLEASE HELP
http://www.jhpusa.com/store/pc/viewP...idproduct=2308
i was looking at this engine here and it comes with everything i need
Engine
Transmission w/ LSD 6 Speed
ECU
Axles w/ half-shaft
Motor mounts
JDM engine wire harness
Starter and alternator
Clutch and flywheel
Intake manifolds
Fuel rail and injectors
Shift cables or linkage
Distributor (if applicable)
but i never seen one in a 1995 CIVIC DX coupe, i really like this engine and heard a lot of good hype about it , but do any of you Pro's think its a good idea? i know labor will be about $1000 or more.. but will the work be way to hard i this pointless?
Old Sep 23, 2011 | 08:33 AM
virgineg6's Avatar
Default Re: K22a? PLEASE HELP
K22?
Old Sep 23, 2011 | 08:55 AM
kyden's Avatar
k20 in an eg? probably the most common k series swap out there.
Old Sep 23, 2011 | 09:08 AM
JDM-Punk's Avatar
yea its pretty common now, but with k's, theres allot more than just buying the motor. def one thing to read up on before buying it
Old Sep 23, 2011 | 09:38 AM
Wrona's Avatar
Engine
ECU
Axles w/ half-shaft
Motor mounts
Clutch and flywheel
Intake manifolds
it comes with everything you need for the motor but you need ECU which is K-Pro, Motor mounts, a tune and im ptry sure there is more than that
Old Sep 23, 2011 | 09:53 AM
Ericezy's Avatar
Oh ok so its not such a risky swap then because i was also looking into the h22's , but the k series seems like its a better motor with it being a fairly new engine
Old Sep 23, 2011 | 11:47 AM
jbrokos307's Avatar
honestly if ur new to this sort of thing id start with a b series in a eg its a very cheap and and easy swap and the hp gain is very practical for a begginer dont blow money on a type r or a b16 do a b18b with a b16 trans you will be happy with that for awhile cause if u dont know how to handle a k series you will just blow your motor right up so start cheap
Old Sep 23, 2011 | 06:04 PM
JDM-Punk's Avatar
said it best... honestly just get a swap under your belt, so you know some ins and outs, enjoy what you got and go from there
TheRookie74
19
Apr 3, 2015 08:56 PM
96 hatch
Feb 22, 2007 10:43 AM
xtimmmyx
Jul 3, 2006 02:31 PM
PreludeDude96
17
Feb 3, 2005 04:00 PM
jffcivic
Feb 22, 2004 08:33 PM
