93 Del Sol stall and won't start - Possible ECM problems?
Old Sep 22, 2011 | 11:36 PM
guitarma's Avatar
Default 93 Del Sol stall and won't start - Possible ECM problems?
I have a 1993 Del Sol approx 150K miles. ran great until a month ago it started dying while driving and then won't start up. City Garage replaced the fuel pump. drove it (3) days, dies again and won't start. Now City Garage wants to replace the ECM! VERY expensive repairs, any thoughts on if this correct or did I get sold a fuel pump when it didn't need it? Thanks for your help.
Old Sep 23, 2011 | 04:44 AM
Former User's Avatar
Default Re: 93 Del Sol stall and won't start - Possible ECM problems?
You need to do some diagnostic tests when the engine WON'T start:
1) Does the fuel pump prime?
2) Does the CEL stay on steady when the key is turned to ON(II)?
3) Is there bright white spark at all four spark plugs?
Old Sep 24, 2011 | 03:12 AM
delsolintegra's Avatar
I had a similar problem with a 93 del sol and it ultimately was the ECU. I had replaced the fuel pump several times and it seemed to help but only for a few months. I also tried the main relay, ignition switch and cleaned the grounds. My ECU had moisture oxidation on the outside of the ECU and I assumed the moisture got to the inside circuit panel. I got a replacement ECU P28 for an automatic for $135. That fixed it.
Old Sep 24, 2011 | 07:33 AM
Go_Race_Your_Self's Avatar
Two Piece
Do what Ron said first than do this..
Check your battery voltage and make sure its around 12v. If its lower than 11v. I would check your charging system. (Alternator) Check all your grounds and clean up any corrosion on terminals.
Kev
Old Sep 26, 2011 | 12:46 AM
guitarma's Avatar
Thanks everybody for the info! Turned out to be the ECM and the fuel pump combined.
splashy
10
Dec 8, 2015 09:25 AM
Wrestler-Dustin
35
Nov 27, 2013 08:15 PM
Ninebr8kr
14
Mar 20, 2012 08:09 AM
delsolintegra
Jun 29, 2011 08:06 AM
h0ust0n_del_sol
Apr 6, 2011 07:40 AM
