gsr turbo 450cc on E85 gas
Old Sep 22, 2011 | 03:46 PM
ja20_eg's Avatar
Default gsr turbo 450cc on E85 gas
Is it safe to run e85 gas on my stock gsr turbo with dsm 450cc...would my injector be enough..my buddy saying ill need more cc injector to run on my motor with e85 gas???
with this set up what would i get for whp and how many lb's of boost i can do?
here's what im running..
custom topmount
precisison sc6176 bb turbo
38mm wastegate
3in dp into 2.5 cat back to exhaust
H.A motorsports p28 s300
Old Sep 22, 2011 | 03:53 PM
turbociv910's Avatar
Default Re: gsr turbo 450cc on E85 gas
yes.
Old Sep 22, 2011 | 03:58 PM
ja20_eg's Avatar
Originally Posted by turbociv910
yes.
yes? my injector will be enough? or not???
Old Sep 22, 2011 | 04:13 PM
92frostwhtdb2's Avatar
Maybe if your car was all motor I'd run 450s on e85...that setup 880s To START
Old Sep 22, 2011 | 06:00 PM
met's Avatar
met
id1000's or more there are some injectors calculators you can find pretty easy by searching Google.
Old Sep 22, 2011 | 06:03 PM
Turpid Porpoise's Avatar
for your setup with e85 you need atleast 1000cc injectors to come anywhere near the potential of that manifold and turbo you have. keep in mind that if takes a much higher flowing fuel system to run e85 than 93 octane or similar fuels.
Old Sep 22, 2011 | 06:15 PM
ja20_eg's Avatar
So what the best bet right if I stay with 450 cc???? 93 pump gas?
Old Sep 22, 2011 | 06:23 PM
92redhatch's Avatar
Just run pump gas. On 450's you can make 350+ on pump gas. It's safe to run e85 but what's the point? If your going for 450whp or more I would tell you to use e85 or race gas but with your fuel setup you won't come close to that
Old Sep 22, 2011 | 06:30 PM
ja20_eg's Avatar
Originally Posted by 92redhatch
Just run pump gas. On 450's you can make 350+ on pump gas. It's safe to run e85 but what's the point? If your going for 450whp or more I would tell you to use e85 or pump gas but with your fuel setup you won't come close to that
With that HP how many lb were talking here....
Old Sep 22, 2011 | 06:39 PM
92redhatch's Avatar
Have no idea how many lbs of boost. Psi doesn't matter what matters is who. I think you can make 300-350 without a problem on pump gas.
Old Sep 22, 2011 | 06:41 PM
racebum's Avatar
absolutely maxed probably.
as others have said, if you're looking at e85 buy 1000s
Old Sep 22, 2011 | 07:03 PM
TheShodan's Avatar
Moderator
260whp in 450cc DSM injectors, not 350 unless FPR raises fuel pressure to maximum.
Get bigger injectors if you want more power or run E85. No more shortcuts.
Old Sep 22, 2011 | 07:08 PM
ja20_eg's Avatar
I got a buddy with 660cc injector..is it worth using those running e85 or pump gas...
Old Sep 22, 2011 | 08:48 PM
met's Avatar
met
http://injector.com/injectorselection.php
Check that link out; its for gas and e85 needs about 30% more fuel. By the time you get those, 660s, get the thing tuned and pay again when you want more its almost worth just getting some bigger injectors to start.
Old Sep 22, 2011 | 10:20 PM
racebum's Avatar
for e85 totally
660s would be a good pump injector but as others have said get the 1k's
Old Sep 23, 2011 | 05:52 AM
Everyone here has and will obviously give you the same answer, with your turbo/mani setup and your desire to run e85 the minimum injector size you need is 1000cc
mrflak0
Nov 30, 2007 12:40 PM
marcussmith26
Nov 28, 2005 12:45 PM
dclsvtec
Mar 2, 2005 03:36 AM
Yellb16crxsi
Aug 23, 2004 09:19 AM
crc245
Jul 9, 2004 10:50 PM
