Low idle at stops. Pls. HELP!!
The car starts up normal, but once it warms up, that's when the rpm go low. Yes, I have to give it a little gas to keep the car alive. It helps a bit when I adjust the screw in the throttle body.
Did this just start all of a sudden?
Did some sort of work precede the problem?
Has the idle been CORRECTLY set (and I don't mean just monkeying with the screw on the throttle body)
Is the Check Engine light on?
