which axel works?
Old Oct 4, 2002 | 05:07 PM
Godspeed91's Avatar
Default which axel works?
I put in a b18a from a 92 integra into my 91 civic hb. Will the axels from the 92 work?
Old Oct 4, 2002 | 05:55 PM
EightOhOne's Avatar
Default Re: which axel works? (Godspeed91)
if you have the int. shaft from the 92 they will work. Just take the dust shield/ring out of your hub, it comes out easy with a screwdriver, and also take out the black plastic ring on the hub end of the axle also..i dont know how to describe it and i can get to hasports site right now
Old Oct 4, 2002 | 06:11 PM
Godspeed91's Avatar
Default Re: which axel works? (EightOhOne)
thanks for the reply. the axels came with the motor. Is what you described on the inside of the axel or the outside by the wheel. is it posted at the hasport site? if so where in the site.
Old Oct 4, 2002 | 06:39 PM
EightOhOne's Avatar
http://www.hasport.com/News/Articles...rt%20Axles.htm
theres a pic from hasport...the one on the hub is metal, and the piece on the axle you need to remove is plastic. Hope that helps
[Modified by EightOhOne, 7:40 PM 10/4/2002]
Old Oct 7, 2002 | 12:42 PM
Godspeed91's Avatar
I did that , but the axles are still about 2-3 inchs too long. Any other sugg.
Honda cd65
Sep 20, 2013 04:18 AM
4drctr420
May 4, 2012 09:57 AM
H22SiRaccord
Aug 5, 2004 12:20 PM
travis brecher
Apr 10, 2004 11:44 AM
Six2Six
May 14, 2002 04:48 PM
