97 civic hb with b18c1 block/b16a head - p1259 code only when GSR ECU is used
Ok, so I have a 97 civic hb w/b18c1 block,b16a head. I got a gsr ecu to used to pass emissions. The cel comes on at start up and throws a p1259, and p1337. the p1337 is from the ckp fluct. sensor not being wired up. Oh yeah I normally run s300 in a p28. So with hondata vtec works great. With the gsr i get the code,(I don't know if vtec engages i haven't driven it to see if it will engage) I did the wire bypass for the lack of ckp fluct.sensor and vtec pressure sensor back when i had the full jdm b16a motor so I not sure if anything else could cause this? I'm going to look at the wiring to see if anything has come apart on fri. any ideas would be great.
FulRebelArmorer
Oct 1, 2013 01:40 AM
94allmotor
Jan 13, 2009 11:25 PM
