Rear car sits lower in one side then the other!
Old Sep 21, 2011 | 07:21 PM
HuchNet's Avatar
Default Rear car sits lower in one side then the other!
I just installed camber kit, skunk2 springs, shocks, lower arms, new rims - tires. After everything was installed, the front and rear were siting lower on one side then the other. I was told to drive it for a bit and it should even it out. Well I got home and the front was even, same as the rear. I went to work today and came back home and relized the rear was siting about 1/4'' from the tired and on the other side there is a good 3/4'' clearence. My driveway is even.
Any suggestiones?
Old Sep 21, 2011 | 07:28 PM
98civdx's Avatar
Master Detailer
Default Re: Rear car sits lower in one side then the other!
What's the camber settings side to side? When I lessoned my negative camber in rear it lifted the rear of the car.
Also, without coilovers, the really is no way to get the car to be level.
Old Sep 21, 2011 | 07:29 PM
94B18EG's Avatar
yeh I have positive camber in rear of my car and it sits higher than front.
Old Sep 21, 2011 | 07:31 PM
akacoke's Avatar
i would just drive for some more see if it evens. although sometimes its like that, nothing you can do. if you really wanna know you should switch L/R to see if the other side is sitting lower
shouldve go with coilovers tho.
Old Sep 22, 2011 | 01:38 PM
EsotericImage's Avatar
Retired Moderator
im wondering if you put the springs in the right location..
I can picture the fronts to one side and rears to the other side..
Brewbot87
Suspension & Brakes
Jun 3, 2014 05:15 PM
Morvpleez
Mar 26, 2012 05:21 AM
GrenadaEG2
Suspension & Brakes
Nov 27, 2009 10:25 AM
2000turbosi
Mar 26, 2006 02:51 PM
Duranged
Mar 24, 2004 07:17 AM
