Rebuilding engine! adding many new parts any suggestions??
Hey guys i am replacing my engine because it was seized and all the internals are trash so i wanna replace ALOT of stuff on the car from top to bottom this is my list so far if im missing anything important let me know here they are
Headers+downpipe "mine have leak"
Front + rear struts
new lowering springs "1 of mine is dead lmao"
new dizzy cap
new stage 1 clutch
new timing belt
head gasket set
rear control arms
crossed and drilled rotors front end
rear end disc brake conversion
new cam gears
all new bushing kit
honda leather stearing wheel "mine is fudged and no horn buton"
new ignition coil
new fuel pump
NGK wires and NGK spark plugs
lightweight flywheel
skunk2 intake manifold
new oil pan and gasket
new O2 sensors x2
rpm gauge "mine seems to not have one lmao"
all of this is $1600 not including labor
half of the stuff i can do myself
plus my engine rebuild which is maybe head job and valve adjustment and anything else wrong with it
i am doing all this because i love my car and plan to pass to wife then son
so did i about cover everything or am i missing some stuff?
Front + rear struts
new dizzy cap
new stage 1 clutch
new timing belt
head gasket set
rear control arms
new cam gears
all new bushing kit
new ignition coil
new fuel pump
new O2 sensors x2
i have had the ac fixxed i had fan in there when ac was not working because my son rides in car didnt want him to sweat to death wasnt working for about a month or so
What do you mean 'Your guessing your engine is fudged or blown'?
What do you mean 'on another note i want to replace a lot of stuff'
First figure out what is wrong, address the problem then move on to your maintenance.
You can buy another civic/teg for 2k. It shouldn't cost that much with all this stuff, but if it is, move on, sell it and buy something else
There is my suggestions
Headers+downpipe - Cheap header and have it mated to your existing exhaust dont use their gaskets, use OEM Honda manifold gasket ( multilayer or whatever, or just a metal orielys )
Suspension - Go to stock
new dizzy cap - sure
new stage 1 clutch - exedy stock clutch kit
new timing belt
head gasket set
rear control arms - ? what about them? NEW Ones?
crossed and drilled rotors front end -dont need, I hear you should go with Brembo Blanks and Hawk hp pads or whatever.
rear end disc brake conversion - dont need rear drums will last, they are lighter, probably fine, just keep the drum. Paint the outside if you want.
new cam gears - dont need them unless your changing timing
all new bushing kit - energy suspension ~$100 ? Looks hard to install them all, mainly rear control arm bushings
new ignition coil - Why
new fuel pump < $100 stock, walbro 255, whatever
NGK wires and NGK spark plugs check hondaautomotiveparts for sparkplugs
lightweight flywheel - whatever sure, do it when you put a new clutch in
skunk2 intake manifold -whatever, not sure why on this one
new oil pan and gasket oem gasket$80 from honda, pretty cheap for aftermarket one, pain to install
new O2 sensors x2 -Why are you replacing them?
rpm gauge - swap the cluster to one with a tach
new timing belt
head gasket set
ty for input my engine siezed up so its screwed just going to rebuild or replace most of the stuff on the list is pretty old on the car or i just want to replace before the problem pops up just looking for some advice pluss iver went through many cars in the past 5 years 3 civics 1 teggy 1 eclipse
now on the body of the car i dont like the tailights will replace soon will sand whole car paint red again rims flat black body kit is bieng repaired soon and fender its my project now my weekend car lol
i have a friend with a shop i was thinking of putting either h22A or D15B not sure yet but n/e way hes gonna handle all the tuning and installing
i see im not the only one who got a crappy tint job on the rear window :3 anywho, you need to figure out what engine youre gonna throw in there first before you decide all the extras. my .02
yea my uncle put the kit and wing on the car i like the look but it needs to be cleaned up the tow truck almost tore the front end off lmao i was looking into the B series i had a b16 in my old hatchie was fast and decent on gas then i had a 4dr ex civic with d16 v tec and i think both are decent i can get a d15 in my area for about 250 rebuilt my friend puts it in for 400 even plus after i fix it up ill most likely sign it over to my wife and upgrade to somthing else she is not about speed she only likes looks lmao so light engine swap then touch up the kit the tint and paint the interior back black i should be good i was just wondering what else should i invest in partwise as well as cheaper engine because b series are common in my part bout 1,500
for engine trans ecu mounts and all that so its a lil bit off my price range but good ideas im still thinking which is good on gas performance and cost =/
OK i decided im going with a d16y8 v tec fits straight into my car no extra changes and the engine only i can get for 400 with only 35,000 miles so that's 400 for engine and 400 for installation sounds like plan ty to everyone who gave their ideas and suggestions =D
do you think you could put it in.. its fairly easy. itll save you 400 and shouldnt take more than a day
I would give anything a swing but i live in apartment and they dont allow any work in parking lot so ide have to have it towed i would deff try to drop old engine out so maybe they charge less atleast but i ave no idea how ive done headers piping radiator altornator o2 sensor and other common maintenance on my cars but never swap lol
yea if you could try and take the motor out at your apt some how, or maybe a friends. because you have to take the motor home somehow so why not just take it out at ur house than hauling it back after they take it out ya know
yea and if they want the parts then they gotta it out them selves
someone might even take the block for out free, just give it to them lol.
might be easyer to sell as whole, just tell them whats wrong.let them sit on the parts till they sell
someone might even take the block for out free, just give it to them lol.might be easyer to sell as whole, just tell them whats wrong.let them sit on the parts till they sell
just go for b series
but now its nice
