Squeaking noise from wheel
Alright here's the thing that's bugging me. When I turn the wheel slowly I can hear a squeaky noise coming from my left front wheel, the inner tie rod has just been changed, and it seems to only appear after I've driven after 15-20 mins.
I have no clue what could be causing this. Can anybody help?
Also it's a '95 Civic
Yea check for contact between tire and splashguards/ panels. Check for the shrouds around the back side of your rotor for being bent and rubbing. Wheel bearing. Could be numerous things
as they all said check that. has the care been re aligned after having the inner tie rode replaced? because it definitely should. if you can not find anything rubbing are the brake pads low/ because they will tend do squeal when the brake bad gets low like an indicator.
The car was realigned when the inner tie rod was replaced, and the whole front brake assembly is brand new. I got my friend to turn the wheel while I listened and it came from around where the tie rod is. I don't know what could be making that noise then.
I have a similar squeaking issue with mine, but I havn't got under it to take a look yet (car's too low). I have been told by a few people that lower ball joints are a common cause of this squeak in Civics
Alright just checked to see if theres a bent splash guard on my brake rotor and theres nothing besides the brake pads touching them.
How would one diagnose a ball joint issue?
projektt
Apr 17, 2009 03:56 PM
carbonlaced
Jun 27, 2006 10:02 AM
Blastek
Oct 18, 2004 08:34 AM
