H22a Swap for a 1995 civic
Old Sep 20, 2011 | 07:51 PM
Ericezy's Avatar
Default H22a Swap for a 1995 civic
Ok so i was real interested in the H22a but WOULD i need to replace the transmission and is it too much work to get the mounts? about how much would it cost. i have already googled it so dont tell me that i couldn't find nothin lol. i have a 5 speed manual so idk if i would need to get that swaped out too
Old Sep 20, 2011 | 08:10 PM
BlackCivicEX's Avatar
Default Re: H22a Swap for a 1995 civic
i dunno ..... google showed me this ..https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%2A%2A%2Ah22a-into-civic-eg-ek-information-post-all-h22a-hybrid-info-here%2A%2A%2A-650329/ and this http://www.hondahookup.com/forums/sh...d.php?t=159651 then this http://cgi.ebay.com/ebaymotors/HASPO...#ht_1684wt_941
Old Sep 20, 2011 | 08:34 PM
kozanatos's Avatar
You can put a D series on the H, but Its not readily available I do not think. ( F2d kits?)
Otherwise yes you need an H series transmission.
They are geared weird, so at 70 your at about 3400rpm
I have one.
Gotta cut out your transmission bracket and bolt a new one in, comes with a kit from hasport or innovative whoever you choose
Old Sep 20, 2011 | 08:43 PM
Mfoehrkolb's Avatar
I have one.
--- old skool kits make you cut... newer ones or better brand kits no longer make you have to cut. I am using avid mounts and they just give an adapter plate for trans side mount. Quite easy and clean looking.
Old Sep 20, 2011 | 08:48 PM
kozanatos's Avatar
dang, I suck then.
atleast Im not wrong on the H2D kits
http://bisimoto.com/store/index.php?...dex&cPath=5_51
but drop a lot of money $1k~
and wait a long time for them to send it to you
just to keep your transmission, maybe if you know your trans is mint keep it?
Old Sep 20, 2011 | 08:52 PM
Mfoehrkolb's Avatar
yeah any h2d or h2b kit is going to be $$$... Transmissions aren't to hard to come by... I bought a h22 trans for 50$... never used it and just flipped it the other day for 250$. It was a M2A4 trans too, the better geared ones. I use a P2T4 trans in my car and its the closest geared trans h/f series has to offer besides for the TWT4 trans. Let me tell you this... I went from a P2A8 trans to the P2T4 trans... and it was an entirely new car after the swap. Went from being able to doing 80mph @ 2.2kish rpms to 80 @ like 4.5kish rpms.
Old Sep 21, 2011 | 05:39 AM
fallrivercolin's Avatar
You don't want to keep a D series tranny anyways. Just use the H tranny. You'll have a stronger tranny, possibly LSD, bigger axles, and much shorter gears!
Old Sep 21, 2011 | 08:41 AM
rhymeshark916's Avatar
h2b kit http://www.quartersportsdrag.com/H2B.html
$750. I'm not a fan of H22. Good luck.
Old Sep 21, 2011 | 09:38 AM
Touek's Avatar
go h2b, type r tranny
Ajsbored
Aug 18, 2013 12:44 AM
beyond305
Dec 29, 2012 03:15 PM
Miklo805
Jan 28, 2012 08:20 PM
WhiteRicer
Sep 23, 2006 07:57 AM
Contender25
Jan 24, 2006 10:54 AM
