Rev/Fuel Cut-off setting
Old Sep 20, 2011 | 12:40 PM
93gsrhatch_1's Avatar
Default Rev/Fuel Cut-off setting
ok so the motor is a b18c with p72 head.,., my question is being that it has stock internals what is a safe rev limit for this.,,. i have it set at 8500 but dont know if i can get more out of it or if i should just leave it alone.,.,any suggestions???? car has I/H/E on a p06 converted to vtec with SST programable chip with s80 lsd tranny.,,.
Old Sep 20, 2011 | 02:00 PM
Relic1's Avatar
Default Re: Rev/Fuel Cut-off setting
valve spings and cams are your limiting factor, leave the limiter where it is.
Old Sep 20, 2011 | 02:06 PM
m_shake's Avatar
I'd put it at 8.2k or so...no sense revving when ur not making power, i'd had quite a bit more work done on my old b18c1 and it didn't make power after like 7900-8100...don't remember completely since its been 2-3 years
Old Sep 20, 2011 | 03:31 PM
i've notived all the hp charts rate it at about 76-8000 to be makin top power.,., also anyone know how i would find out which b18c it is i've notived 2 different hp ratings for the motor code which one is which
Old Sep 20, 2011 | 03:32 PM
also one makes 197 and one makes 187 hp
Old Sep 20, 2011 | 03:51 PM
93egSLEEPER's Avatar
Another key besides just revving til youre out of power is making sure when you shift youre in the optimal powerband and not dropping too low. With that said its hard to say without getting on a dyno...
Old Sep 21, 2011 | 08:13 AM
m_shake's Avatar
Yup yup!
Old Sep 21, 2011 | 06:41 PM
PyroProblem's Avatar
JDM Integra type R (B18C) 197 HP
JDM Integra GSR (B18C) 180HP
I think...
Old Sep 26, 2011 | 06:34 AM
I think...
So then would the head make the difference?? with it being a GSR p72 head??? with the type R being pr3?
Old Sep 26, 2011 | 07:21 AM
JDM Integra Type R (B18C) has better cams and valvetrain, bigger throttle body, actual tubular exhaust manifold/header '98+, different ecu mapping, higher compression, hand blended bowls in the head, and an intake manifold better suited for higher rpms...
The JDM GSR (also a B18C) is just like a standard USDM GSR but with different ECU mapping and slightly higher compression pistons I believe...
So to answer your question, its probably a little bit of everything that helps bump up power...
B_Swapped93
17
Apr 4, 2013 12:51 PM
Mo_Spec
Jun 8, 2011 09:40 PM
hott-nix
Sep 20, 2004 11:12 PM
TurboB18C1
Jul 18, 2004 05:44 PM
milanoGSR
Oct 24, 2003 07:07 AM
