alternator problem in b16 crx
Old Oct 4, 2002 | 03:11 PM
chirp2hrd's Avatar
Default alternator problem in b16 crx
hey my alternator has gone bad i have the new one but do i have to take out the axle to put the new one in???? how do i go about putting the new one in?
Old Oct 4, 2002 | 06:04 PM
chirp2hrd's Avatar
Default Re: alternator problem in b16 crx (chirp2hrd)
TTT
Old Oct 4, 2002 | 06:50 PM
djay86's Avatar
https://honda-tech.com/zerothread?id=294393
Old Oct 5, 2002 | 07:24 PM
PnX-R's Avatar
Now how in the world did you figure out that your alternator went bad?.. Did it tell you that?.. No, it can't talk.. I'd love to know how you came about with that decision.. It would help a whole lot..
Old Oct 6, 2002 | 09:05 AM
chirp2hrd's Avatar
Default Re: alternator problem in b16 crx (PnX-R)
ok mang i go thru recharged batts and they die after a couple of hours and i did the check thing for the alternator it was pull the neg cable pff the batt and if the car wants to shut off its ur alternator OK so i am pretty damm sure its the alternator do you have any better ideas???
Old Oct 7, 2002 | 03:54 AM
PnX-R's Avatar
If the alternator isn't charging. Check to see if the Voltage Regulator is dumping the power straight to Ground. You can also check the Rectifier and see if you fried any diodes.. But if it's your Voltage Regulator and it's dumping to Ground, just fix the wiring and same some money..
BoltonGSR
Jun 22, 2008 07:14 AM
mymeatb18"
Aug 15, 2006 10:35 AM
92silude
Jun 14, 2005 12:11 PM
92silude
Mar 14, 2005 09:29 AM
bullet9925
Feb 28, 2004 08:34 PM
