windshield wipers won't work - blown fuse
Old Sep 19, 2011 | 07:20 PM
Rach25's Avatar
Default windshield wipers won't work - blown fuse
Hi. I tried to turn on my windshield wipers but they wouldn't work. I check the fused, it was burned out. Replaced it and I tried to turn the wipers on and it worked but I tried again and they won't work. So is it the motor or something else?
2000 Honda Civic.
Old Sep 19, 2011 | 07:35 PM
EsotericImage's Avatar
Retired Moderator
Default Re: windshield wipers
did the fuse blow again?
Old Sep 19, 2011 | 07:39 PM
virgineg6's Avatar
x2
Old Sep 20, 2011 | 06:46 AM
Rach25's Avatar
Default Re: windshield wipers won't work - blown fuse
yes the fuse did blow again.
Old Sep 20, 2011 | 07:02 AM
virgineg6's Avatar
Check your wiring might have a break or a tear somewhere thats grounding out causing the fuse to blow
Old Sep 20, 2011 | 07:45 AM
Go_Race_Your_Self's Avatar
Two Piece
x2
When you got a short that grounds before the consumer it will blow the fuse since the consumer didnt use the power.
Kev
Old Sep 20, 2011 | 01:08 PM
Rach25's Avatar
I am not a car person. Where can I find the wires to see if they broke or have a tear in it?
Old Sep 20, 2011 | 04:08 PM
Former User's Avatar
Does unplugging the windshield wiper motor prevent the fuse from blowing?
Old Sep 20, 2011 | 07:39 PM
Rach25's Avatar
Where is the motor? I am not a car person.
Old Sep 20, 2011 | 07:57 PM
Does the fuse blow only when the wipers are turn on? If so, does the fuse blow when the wipers are set to low or high?
Do you have a multimeter?
Old Oct 7, 2011 | 12:51 PM
Rach25's Avatar
Hi again. I took my car to a car shop and they said it shorts out when I do the wipers for the wiper fluid. He got it working temporaily but he says he wants it for a full day. What does that mean? Could it be the motor or the wiring? I just want to know.
Old Oct 7, 2011 | 12:54 PM
grumblemarc's Avatar
The Grumpiest
What does that mean "he wants it for a full day"? You should have asked HIM that question. Did you ask him what he was going to be doing for the day he wants to keep it? How much is this going to cost you? All questions you should have asked him, not us.
Old Nov 27, 2012 | 12:28 PM
Sheena Vera's Avatar
Icon2 Re: windshield wipers won't work - blown fuse
I'm having the same problem with my windshield wipers. Did anyone resolve the issue and know the answer to why this happens?
Old Jun 15, 2013 | 08:49 PM
Dadmechanic's Avatar
I had same problem and found a short near the firewall where the wiper motors wires come through into the engine area. The wires are wrapped in plastic flex hose before and after the firewall. Through the firewall they aren't wrapped and one of the wires insulation was worn through with the copper wire exposed. This looks like a poor way to route cables - should be wrapped here as well. Hope this helps someone isolate their problem.
Old Oct 5, 2015 | 10:24 AM
Lop1's Avatar
Hello, I have the same problem, but at the same time light on the "brake lamp light", any one have the color code or diagram?
Lop1's Avatar
I have the same problem, anyone have the harness diagram or wire color code?
NACvicSi
Aug 27, 2009 05:03 PM
Mishima
Jun 30, 2009 09:08 PM
BLUE EH3
Mar 15, 2007 12:24 PM
illusion
May 29, 2003 11:07 AM
ModlesSI
Feb 22, 2003 03:16 PM
