Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Newbie ignition help..
Old Sep 19, 2011 | 01:33 PM
joel n's Avatar
Default Newbie ignition help..
This is my first year racing, I share a 95 honda del sol with a B17 VTEC motor swaped in it. Last race weekend we had a bad misfire, checked it out, and replace the coil and engine control module in the distributor. Put a new cap, rotor, plugs and wires on it. We found a few connections were loss so we tightened them up. Then the car ran much better, But if the motor wasnt completly warm it would miss, only a small amount. Now after the owner ran a sprint with it, Went its cold it misses really bad, and even warm if your not above 5000RPM it will miss. Anyway, i am not a big eletrical guy, but i have a non VTEC B18 distributor as well, will this one work, The engine control module part number was the same for both VTEC and non-VTEC motors.
Any help would be great.
Old Sep 19, 2011 | 02:44 PM
dirty19's Avatar
Ridin Dirty in Cali
Default Re: Newbie ignition help..
Sometimes the engine forums are more informative than we would be.
Id swap out the dizzy and see what happens but only with a b17.
make sure the plug gaps are correct.
Also double check the engine timing.
l.holmes
May 18, 2016 11:12 AM
Jahtoot84
Jun 21, 2005 06:46 AM
xynz
Jun 15, 2005 04:56 PM
Touch
12
Apr 9, 2003 10:35 AM
