crv cluster in EK question
i have a crv cluster i am putting into my 96 dx hatch. took the old one out and was putting the new one in plugged in both blue plugs on the top and the one yellow one on the back. put everything back together and the tac doesn not work. ANYONE KNOW WHY THE TAC WOULDNT BE WORKING??!!
You'd probably get a better answer if you posted this in the correct forum
Try a different cluster with a working tach and try that. If that works, you got a problem with your cluster. If it doesn't work with the working cluster, you got a wiring problem
Hybrid_ek
Aug 10, 2005 09:09 PM
