Clutch Contamination
Old Sep 18, 2011 | 06:09 PM
curtie94's Avatar
Default Clutch Contamination
I have a valve cover leak and am wondering if a leaking valve cover could cause clutch chatter. When I first take off in the morning the car shakes horribly. Only in first. If i'm driving down the road and tap the gas the car shakes like it does off the bat.I have a valve cover leak and am wondering I I fix that will it fix its self or do I need to change the clutch.
Old Sep 18, 2011 | 08:17 PM
nus_dogg's Avatar
Default Re: Clutch Contamination
If the clutch is soaked in oil, it needs to be replace with a new one. It won't fix itself. But how does a leaking Valve Cover contaminates the clutch disk? It's gotta be something else like the rear main seal or something near by.
Old Sep 18, 2011 | 10:03 PM
slomofo's Avatar
GDD Member
Best thing to do is run down to a mechanic shop and have someone else drive it for you. Most small indy shops don't charge for a quickie test drive. Sounds to me like a random misfire or clogged fuel filter and not a clutch issue.
Old Sep 19, 2011 | 02:09 PM
curtie94's Avatar
The whole motor is soaked thats the only reason why I though valve cover. My plug wires are old and cracked. Lately the car hasn't started right up like it used to are these to related?
Old Sep 19, 2011 | 04:36 PM
accordmatt's Avatar
the whole issue is the leak. its causing a misfire and making it shake like that. u need to replace valve cover gasket set,new plugs,wires,cap,rotor and clean all the oil and crap up and u should be good to go.
Old Sep 19, 2011 | 05:31 PM
curtie94's Avatar
Does my problem sound like a miss fire to anyone else. I am only curious if you think the problem will stop if I fix the leak then do a tune up?
Old Sep 20, 2011 | 04:27 PM
Lost Again's Avatar
Is there oil in the spark plug tubes as well.
Old Sep 20, 2011 | 04:54 PM
curtie94's Avatar
Yes cylinder 3 is full of oil.
Old Sep 20, 2011 | 05:21 PM
poorman212's Avatar
I'd start with the tube seals before getting into the clutch....could still be the clutch but I would like to rule out the easy stuff.
Old Sep 20, 2011 | 05:42 PM
curtie94's Avatar
Ok so I will do the valve cover gasket and plug gaskets. But the oil has been on the plug wires since I got it in August 2010, just recently it started to shake like that like March 2011. So I will try valve cover gasket and plug gaskets. If that doesn't fix it are there any other ideas/
Old Sep 20, 2011 | 11:37 PM
holmesnmanny's Avatar
Sounds like cylinder 3 is just misfiring from all the oil and maybe the wires are now breaking down. Normally the flywheel sprays the oil out of the casing and even in the most extreme cases of leaks the oil won't make it to the clutch since there just isn't enough leaking out at one time.
Jesse M
Honda Civic (2001 - 2005)
May 3, 2019 08:06 AM
Nicholas Bailey
Transmission & Drivetrain
May 13, 2016 05:51 PM
joiv21
14
Jun 6, 2013 01:59 PM
Cuong-nutz
Apr 22, 2005 02:30 PM
BrandonClaps
Apr 20, 2003 04:43 PM
