Transmission Problems (heeeeeeelp!)
Old Oct 4, 2002 | 01:34 PM
Chuji's Avatar
Default Transmission Problems (heeeeeeelp!)
Ive been screwing around with my tranny for a month now and I cant get this peice of **** to shift right. Can someone please tell me whats not workin here. I swapped everything inside of a 98 gs-r tranny into my 96 LS case. I put it back together and it shifts 1-4 smooothly, 5th is kinda hard to get in and reverse doesnt go in. I have no tranny fluid in the tranny, im not sure that this makes a difference though, it just doesnt go into reverse at all. So I take it back out and replace everything that connects to the shifting mechanism and I also replace the 5th gear shift fork and the bar that connects to reverse. I put it back in and still the same thing. Any ideas?
Old Oct 4, 2002 | 01:43 PM
Stupid Ass's Avatar
Default Re: Transmission Problems (Chuji)
You drove it without fluid? Or your in the middle of a swap?
Old Oct 4, 2002 | 01:54 PM
Chuji's Avatar
Default Re: Transmission Problems (SOHC NoTEC)
In the middle of a neverending swap
Old Oct 4, 2002 | 02:08 PM
CHEETAH's Avatar
you need to use a gsr maingear and the necessary syncromeshs where the LS wont fit, i.e. 3rd. The two casings are not directly interchangeable ...
Usually you cn swap in the LS 3,4 and 5 counter and main gears using all other GSR internals ... but not the complete LS guts.
also, which ring gear ? LS 64 teeth or gsr 66 teeth ?
Greg
Old Oct 4, 2002 | 03:18 PM
Chuji's Avatar
Default Re: Transmission Problems (CHEETAH)
I am using all gs-r internals, I swapped the mainshaft and everything.
gsrgirl4u
11
Jul 5, 2007 08:48 PM
TASH391
Mar 10, 2006 03:31 PM
95 RED CIVIC
Oct 6, 2005 09:50 AM
love2xlr8integra
Jun 26, 2004 11:22 PM
JDMCivicEF9
May 4, 2003 02:25 PM
