Check Light Engine & D4 Flashes
Ok so my problems started after i changed my oil -
valvoline Durablend. Car worked fine. Then turned off whenever the rpm was forced to get low, such as when reversing. at a stop light.
I check the battery : good
ALtenator: good
now i think it may be the fuel pump. i put some Seafoam Cleaner in the gas tank after that my car was stuck in the D4 gear car did not brake. BRAKES DID NOT WORK!
I now can drive the car however, the check light engine comes on and the D4 light starts flashing
I did the CEL Check light engine test and the check engine light did not flash however the D4 did. It was one Long one. and then 4 short one
I drive a 1994 honda accord lx
Thanks, nd i really like this car, hope to get it fixe soon
ALtenator: good
ok so according to alldatapro you have a short or open in FAS (brown/whte) wire or a fualty ECM. is the mil lamp on if so u have to repair the PGM-FI system.
