brake booster differences
Yes, the boosters are are different. You may be able to adjust them to work with the opposing MCs, but I have not heard of anyone doing that.
and its NOT a TYPE S!!!!!! the Master cylinders are slightly different on the mounting surface. I forget exactly, but one has a small area notched out to prevent one from fitting onto the other.
As for the booster itself the SI has a longer rod inside it which caused my front brakes to lock up completely after driving it for a mile or so after heating. I had to release the built up back pressure on the master cylinder itself to release the brakes. Finally i switched the booster for a 90 accord sedan non ABS..works great.
sonic47
Aug 18, 2009 10:33 AM
DRKSol
Sep 14, 2004 09:04 AM
