Upgrading Grounding wires - can you suggest data gathering to compare before/after?
Old Sep 16, 2011 | 09:18 AM
DSMAddicted's Avatar
Default Upgrading Grounding wires - can you suggest data gathering to compare before/after?
Guys,
I am about to replace the old and corroded ground wires in my engine bay with brand new 6GA wire.
Can you please help me figure out the best way to collect data while I perform this procedure?
Right now all I can think of is the following:
  • Check voltage the alternator is putting out before and after each ground replacement (@ idle I suppose?)
  • Check resistance of each ground wire (old vs. new)
Please note: I'm not asking whether I should do this or what benefits I should expect. There are plenty of threads with that kind of info. I've done lower gauge grounding upgrades on previous cars in the past and always noticed smoother idling, start, light improvements and similar changes. My current grounds are old and damaged... all I want is for everything to be properly grounded and I got my hands on some nice black 6GA wire. That is all.
Thanks!
Old Sep 16, 2011 | 10:54 AM
joeshmo's Avatar
Default Re: Upgrading Grounding wires - can you suggest data gathering to compare before/afte
Originally Posted by DSMAddicted
Guys,
Thanks!
Check the total resistance up the wire to the negative battery terminal. The measure will likely be VERY small, both with old and new wire so adjust your multimeter accordingly.
Coopa B18c5
May 6, 2013 02:09 PM
stevenr2894
10
Mar 9, 2013 10:23 AM
Wazup
Apr 18, 2011 04:04 PM
pearlteg
Apr 17, 2004 10:52 PM
vidanator
Aug 30, 2003 05:25 PM
