oil squirters???
so i have a jdm b16a and have searched for this info but cant find anything rock solid.
i want to know if b18cr oil squirters can fit on the b16a... the bottom end has a b18c crank, b17a rods, and oversized pistons (82mm) where the rist pin is moved up 3mm for clearance.... so w that said can they just bolt right on or wat???
why wouldnt u need them w aftermarket pistons, i hear that a lot but it just seems like a good idea to use them especially if im high reving and if i do plug them how do i plug them up, like wat do i use????
Oil squirters were designed for higher rpm and with factory cast pistons. If running forged no worries.
cool so i guess i will just not waste the money on them but back to wat i use to plug them??? do they make caps to plug them up or do i have to customize???
OasU
Jun 13, 2012 01:33 PM
