do spark plugs NEED to be removed for valve lash?
Old Sep 14, 2011 | 11:00 PM
sebTeggy's Avatar
Default do spark plugs NEED to be removed for valve lash?
Why would they? I am just wondering. Planning on doing a huge valve lash with some friends, and one of them has a seized plug. Thanks!
Old Sep 14, 2011 | 11:02 PM
TOO MUCH TORQUE's Avatar
Default Re: do spark plugs NEED to be removed for valve lash?
nope, it just eases turning over the engine by hand
Old Sep 14, 2011 | 11:06 PM
sebTeggy's Avatar
Wicked, thanks for the midnight reply. How does the spark plug increase turning the engine over? Just wondering! I can't visualize this =S
Old Sep 14, 2011 | 11:12 PM
LordAphotic's Avatar
its because as your engine enters the compression stroke of the combustion cycle the valves are closed so you are pressurizing air and fuel or in your case just air... it gives u a lot of resistance so taking out the sparkplugs allows that air that normally would be compressed to escape out the spark plug hole making it easier to rotate the assembly
Old Sep 15, 2011 | 11:56 AM
sebTeggy's Avatar
Of course! Thanks man haha :D
Old Sep 15, 2011 | 12:00 PM
v8killaz's Avatar
lol you sure you want to do the valvlash
Old Sep 15, 2011 | 09:34 PM
dago25trizzle's Avatar
make sure the engine is stone cold, or it can affect your measurements
Old Sep 15, 2011 | 09:52 PM
sebTeggy's Avatar
hahaha^ I Just realized I told everyone 'to meet me' for their valve lash adjustments, how SILLY of me.
Old Sep 15, 2011 | 10:06 PM
Spawne32's Avatar
ive never had a problem rotating the engine with the spark plugs in lol and i do it with a 3/8 ratchet and about 8 extensions lol
Old Sep 16, 2011 | 06:17 AM
GagnarTheUnruly's Avatar
Removing the plugs gives you an excuse to look them over, so you might as well take them out, especially because it makes it significantly easier to rotate the engine and spark plugs aren't exactly hard to remove.
Old Sep 16, 2011 | 08:09 AM
sebTeggy's Avatar
Thanks for the tip. Although that isn't really why I was asking. Friend had a crossthreaded plug but needs a lash adjustment, I figured I'd make sure
DDTECH
27
Sep 29, 2009 11:01 PM
josh's ep3
14
Jan 30, 2009 09:57 AM
tuquikgsr
Dec 18, 2008 09:40 PM
toooslow
May 14, 2003 11:37 AM
falcongsr
Honda Motorcycles
Dec 16, 2002 07:13 AM
