Z6 Smokes. Help me source it please!
Old Sep 14, 2011 | 04:45 PM
SlowPokeEg's Avatar
Mike Jones
Default Z6 Smokes. Help me source it please!
D16z6
75.5mm Vitara + FJ bottom end
Stock head
Precision 5431 Turbo
Motor was completely rebuilt. Head was gone over, and longblock was assembled by local engine shop.
Ended up getting WAY behind schedule to finish it and didn't get it running until the night BEFORE the tune. It idled great and didn't leak, so we packed it up and trailered it to get tuned.
Tuner broke in the motor on the dyno, stating that keeping the car at 1500rpm or so for a certain amount of time will break in the rings. Also had 5w30 break-in oil in it. Car idled a little high (and somewhat surging) and he had to clock the dizzy way over which did not make sense!?!
Car did very poorly, only putting down 272/217 on 20psi. I was pretty heartbroken. It did puff a few clouds of smoke while tuning, but I figured it was still being broken in.
Well, after a tune, and 300 miles of pretty conservative driving (a few rips here and there), the car is now smoking like a freight train.
We thought it was either: Valve seals, Headgasket, Turbo, or rings.
Did a compression test tonight....
#1 - 145, 140
#2 - 155, 155
#3 - 190, 190
#4 - 185, 180
Added oil to 1 and 2......
#1 - 225, 200
#2 - 210, 200, 185
Obviously the oil is seeping past the rings since the numbers decrease each test
Are my rings garbage? Should I just change the oil and keep breaking the motor in and try again?
On a side note, my catch can is bone dry, which does NOT make sense if I'm getting that much blow-by. Also, when I pulled my plugs, they were maybe a little darker than they should, and smoke/vapor was fuming out of spark plug #2 if that helps diagnose it at all.
Thanks HT! I'm going to cry now.
Old Sep 15, 2011 | 06:26 AM
SlowPokeEg's Avatar
Mike Jones
Default Re: Z6 Smokes. Help me source it please!
RLY?
Old Sep 15, 2011 | 07:29 AM
wmac's Avatar
sounds like your rings didn't seat.
i always heard you should vary the rpm during break in, w/lots of compression braking.
that's worked a couple of times for me.
Old Sep 15, 2011 | 07:40 AM
SlowPokeEg's Avatar
Mike Jones
Well he kept it at 1500 for a while, then went right into the tuning session.
If they havn't seated by now, will they ever?
Old Sep 16, 2011 | 05:21 AM
didurgf's Avatar
Old Sep 16, 2011 | 03:52 PM
blackeg's Avatar
you might be past the point of being able to seat the rings still...a hone and new rings could be in order. interesting that they are the 2 adjacent cylinders that are bad... are you mixing oil and coolant by any chance?
Old Sep 18, 2011 | 04:50 PM
SlowPokeEg's Avatar
Mike Jones
https://honda-tech.com/forums/forced-induction-16/bad-weekend-z6-2980677/
No, there was no mixing of fluids. Oil looked fine when I did an oil change after 300 miles of break in. Also, there was never any overheating of the engine, even though when I opened the hood it felt extremely warm.
alanviosca
12
Aug 27, 2013 04:28 PM
EJ8chu
Oct 28, 2008 08:03 AM
boostfreak0885
Jan 22, 2008 04:07 PM
toolow69
Jun 18, 2007 05:40 PM
1 2 NV
21
Jul 19, 2006 09:39 AM
