H23 intake manifold?
Old Sep 14, 2011 | 04:32 PM
horsepowerless's Avatar
Default H23 intake manifold?
Ok, so I've seen this question, and read the answers already on this forum as to the fitment of an H23A1 intake manifold on an F22A1. So I know that it's a direct bolt on.
What i haven't seen discussed, however, is do I need to do anything to my ecu or fuel system to see the power gains for my 96 prelude S from an H23 intake mani, or can i just bolt it on and go?
Old Sep 14, 2011 | 04:48 PM
preludeNApower's Avatar
Default Re: H23 intake manifold?
pretty sure you dont need to change anything
Old Sep 14, 2011 | 06:47 PM
SnlpeR's Avatar
your secondary butterflies wont open/close properly
Old Sep 14, 2011 | 07:45 PM
Oh.. I knew there had to be a catch. How do I fix this?
Old Sep 15, 2011 | 02:17 AM
SnlpeR's Avatar
one way is to wire an RPM switch.
you can use a shift light
when it reaches a certain rpm..itll send a signal to control the actuator on the vacuum box under the manifold
probably best to install a relay and fuse in between
got mine to work properly and now i can let my secondary butterflies open whenever i want
Old Sep 15, 2011 | 05:35 PM
thanks for the info! ill definetly look into these options. i really want to give my car a little more power so i can enjoy it for at least a year until i can upgrade cars.. i don't want to do the whole h22 swap though because I have an auto and id have to install a bunch of stuff along with the engine.
Old Jan 1, 2012 | 11:09 PM
Dr.Honda's Avatar
the butterflies are to add low end torque for daily driving, and open at wot or a certain rpm for more air flow correct?
Old Jan 2, 2012 | 10:35 AM
Hidenplanvew's Avatar
Basicly your right... You can just take them out and scream on the top end
Old Jan 2, 2012 | 11:05 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Why would it "scream on the top end" with the butterflies out? The butterflies open up at a higher RPM and throttle position anyway. So...it'll "scream" as much as normal on the top end. It'll be kinda boggy down low with the butterflies out.
Old Jan 2, 2012 | 11:30 AM
Because I said so!!!
I ment like take them out all together and open it up by removing the honey comb stuff
Old Jan 3, 2012 | 10:41 AM
Dr.Honda's Avatar
i understand it being boggy down low, but a lighter flywheel would compensate for this correct?
Old Jan 3, 2012 | 02:49 PM
typemismatch's Avatar
Honda owns me
The bog isn't that noticeable in the low end, I gutted the butterflies out of mine.
There is a benefit to taking them out, without them the air flow in the manifold is less turbulent.
Old Jan 3, 2012 | 04:39 PM
Dr.Honda's Avatar
i read in another thread that removing the iabs is only effective if a spacer is added. i think a thats completely open if you get what im saying
Old Jan 3, 2012 | 05:32 PM
Honda owns me
When you actually take one apart you'll understand.
If you take the butterfly plates off you're left with an actuating rod going through the middle plate, its much less turbulent than having plates in there.
Old Jan 3, 2012 | 07:08 PM
Dr.Honda's Avatar
oh you mean actually take out the butterflies. i was talking about the entire section.
Old Jan 4, 2012 | 04:19 AM
Update: Luckily I didn't have to fool with any of this. My dad and I ended up swapping in a jdm h22. ill post a build thread soon as i also recently painted my car.
Old Jan 4, 2012 | 06:36 AM
Honda owns me
The H22 IM has these butterflies too, you can take them out as well
Old Jan 4, 2012 | 06:38 AM
Honda owns me
Messing with that means a spacer or all new bolts and who knows what other misc BS ... just unscrewing them from the actuator rod and leaving the rod in there ... sooooo much easier
Old Jan 4, 2012 | 05:40 PM
Or just pull the rod and jb weld the holes.. Bore out the little sections into one whole open part
Old Apr 2, 2013 | 06:35 PM
Mishako129's Avatar
I gutted out my H23 manifold completely. Just waiting now for the heat gasket to come in the mail,
It's not the finished product,
slo2k
Jun 9, 2011 09:02 PM
fastazzf22
Jul 15, 2007 02:23 PM
deeweezy187
Dec 12, 2005 04:15 AM
