Transmission & Drivetrain Gearboxes, Differentials, Clutches
re-using diff bearings?
Old Sep 13, 2011 | 02:38 PM
vtechjunkie's Avatar
Default re-using diff bearings?
I have a Quaife differential that I am installing into my S4C tranny, and there aren't/weren't any shims in the case. I know the tranny is good, as I drove the car before I pulled it. What I need to know is can I re-use the bearings(sealed btw), if so, how do I tell if the bearings are still good to use? They roll freely, and have no play. Does that mean they are still good to go?
Old Sep 13, 2011 | 02:39 PM
Gearspeed-Performance's Avatar
Default Re: re-using diff bearings?
They are cheap to replace $25 for the pair...I would install a new set There should be a thrust shim in the main case?
Here is a list of sizes
Old Sep 13, 2011 | 03:30 PM
Very true, I was just wondering if it were overkill. Thanks, I will check to see if there is a shim there.
Old Sep 14, 2011 | 11:49 AM
Mista Bone's Avatar
D Tranny Guru
All LSD's I install get fresh diff bearings. You can flat spot the ball bearings when pulling them off.
TB123
11
Apr 12, 2009 11:06 PM
mgags7
Sep 28, 2005 06:31 AM
b20guy
Mar 26, 2003 06:07 PM
SlowTeg
Aug 6, 2002 08:06 PM
