Oil Leak
Old Sep 13, 2011 | 02:15 PM
jumpin4abeat's Avatar
Default Oil Leak
So I went to do an oil change today, popped the hood and noticed that oil was leaking out of the head. There is like a little black plastic cap looking thing and oil is leaking out from around it. Does anyone know what this piece is or if something is supposed to be attached to it? Its on a b20b motor. If looking at it from the front, its located on the left side towards the front.
Old Sep 13, 2011 | 02:18 PM
95civic_ferio's Avatar
Default Re: Oil Leak
valve cover screw?
Old Sep 13, 2011 | 03:19 PM
motegicivic's Avatar
Take a pic.
I am wondering if your head gasket is leaking oil.
Old Sep 13, 2011 | 03:47 PM
rhymeshark916's Avatar
Oil cap, probably wasn't screw down.
Old Sep 13, 2011 | 04:06 PM
BryanM.'s Avatar
Resident Gearhead
He's talking about the cam plug guys.
Some aftermarket plugs like the one pictured below are supposed
to seal better than the OE units.
Old Sep 13, 2011 | 04:17 PM
Well, my assumption was that he went to get an oil change. He didn't perform the service. He paid someone to do it. So the lube tech might have forgotten to tighten up the oil cap. I've done that before when I was a tech at Honda.
Old Sep 13, 2011 | 04:23 PM
here is a few pics. Its the black plastic thing.
Old Sep 13, 2011 | 04:26 PM
In that first pic you can see the oil actually on the bottom of that circular black thing. I dont know what it is, if its cam thing or not. I know what an oil cap is though and i know its not that but could be lol it is plastic. Anyways, is it sealable or do I need to add something to it? If I can seal it what do i use?
Old Sep 13, 2011 | 04:27 PM
Looks like you're leaking for while. And valve cover gasket kit? Head gasket? I would clean your block off and see what else is leaking.
Old Sep 13, 2011 | 04:31 PM
99civ's Avatar
I leak from there too and have the same motor... High five! I just clean it and go, it only leaks when I beat on the car.. I need to start making a little list for the winter though!
Old Sep 13, 2011 | 04:34 PM
It's a cam seal. Cheap to replace. Make sure you use some Honda bond when installing it. Clean up the block first to see what else might be leaking.
Old Sep 13, 2011 | 04:38 PM
99civ's Avatar
Brake cleaner should clean it no?
Old Sep 13, 2011 | 04:40 PM
Yeah, or de-greaser and wipe.
Old Sep 13, 2011 | 04:48 PM
Leaking elsewhere? Is there anything inside or is it just the housing? I know its only leaking from that plastic piece. In replacing the cam seal, I dont have to open the head gasket or anything like that do i? I had a bad experience with a head gasket on a 00 mustang and I swore to never do it again.
99civ's Avatar
Yeah that's what i used on my old 16. I know for sure I have brake cleaner outside that's why I asked. Here's a dumb question for the smart... Can I order acura parts at a honda dealership? Reason I ask, I have like 10 Honda dealerships to every 1 Acura in my area.
Old Sep 13, 2011 | 04:49 PM
List of what for winter? I just got the car in the summer, anything special for winter? I do run it hard, take it up to 90 in 3rd always.
Old Sep 13, 2011 | 04:53 PM
Sure you can. Just cross reference the part numbers.
...then you're on your own.
Old Sep 13, 2011 | 05:08 PM
Do you have to remove the head gasket to get to the cam seal? I was thinking I could seal it from the outside, is that not correct? Why is everyone saying a degreaser? How will that stop the oil from leaking? I dont wanna clean it if its going to come back kinda defeats purpose of cleaning it.
Old Sep 13, 2011 | 05:34 PM
I found a video on youtube on replacing cam plug. Is it true it just pops out and all I need is a new plug which is about $15 and some hondabond and it just pops back in?
Old Sep 13, 2011 | 06:25 PM
It does seem that simple, an external job.
Old Sep 13, 2011 | 07:32 PM
99civ's Avatar
To clean the block so you know its the ONLY thing leaking... and for the one asking for "winter" because I need to make a list of small ****(leaks, electrical) to fix over the winter.. I have a 97 DX I drive daily and through the winter here in Ohio.
Old Sep 13, 2011 | 11:17 PM
hannslebo's Avatar
Ahhaha...the first couple reply posts!!! lolzzz!!
C'mon fellas!!
Sorry to go off topic!!! Its your cam seal as stated above...simple, low cost repair.
Carry on....
Razr2
Jan 22, 2008 09:47 AM
siresword
Oct 25, 2007 12:28 PM
Serenity Now!
Jan 29, 2007 06:31 AM
deepnite
Oct 9, 2002 01:46 PM
FlipboiGSR
Aug 24, 2001 07:41 PM
