Plug issues
Old Sep 11, 2011 | 11:39 PM
hksitr's Avatar
Default Plug issues
iv got b20b with 12.5 compression
it was running fine on NGK iridum BKR6EIX-11 on its base tune. then i switched to NGK iridum BKR7EIX-11 (same base tune). ever since iv changed the plugs. it starts running like crap like missing etc on light throttle and surging. the plugs were at 1.1mm when new. i regapped them to 1mm (0.040") same thing.
what everyone running them on high compression motors?
iv got another b18c similar compresion same plugs but no issues
so inputs. could it just be a simple retune to suit plugs
Old Sep 12, 2011 | 01:16 PM
EsotericImage's Avatar
Retired Moderator
Default Re: Plug issues
Why not get it tuned properly then see what happens
Old Sep 12, 2011 | 01:37 PM
00Red_SiR's Avatar
All Motor Mentor
check to make sure all your plug wires are installed firmly and correctly. If yes and if possible, reinstall your old plugs and see if the problem goes away.
Old Sep 12, 2011 | 02:28 PM
hksitr's Avatar
the reason why its on it base tune. cause the motor just getting a run in first before final tune. car runs fine on old plugs which are the hotter plugs. the leads etc are firmly on
Old Sep 12, 2011 | 03:02 PM
DDTECH's Avatar
You should be on 7's to begin with, try the copper 7's.
Old Sep 12, 2011 | 03:03 PM
00Red_SiR's Avatar
All Motor Mentor
If you've swapped the plugs back and forth to confim this, try swapping one new plug out with an old plug. Keep doing this one at a time to see if it goes away and what plug may be the cause of it. It may be that one of your new plugs is bad but it's unlikely that the heat range is your problem.
fast93accord
Jul 4, 2005 07:54 PM
johnzm
19
Oct 4, 2004 10:59 PM
LSVTEC 91 Civic
May 16, 2004 04:24 PM
r7
Aug 26, 2003 05:18 AM
ALLMOTOR18
Sep 10, 2002 03:05 PM
