Ls v smoking
Sup people.. Newbie here so please bare with me. I have a 94 Acura integer and I just rebuilt the motor. New rings, bearings, cylinder honed, valve seals, head pressure tested. Motor work was done by machine shop. Problem I'm gettin is the car is smoking blue smoke. Especially goin down hill.. Goin up hill doesn't smoke but when leveling out vehicle tends to smoke. Machine shop said the rings I got were chrome plated rings so is kind of a pain to seat them, he says smoke should clear up within 200 miles. I have 100 miles on it and smoke has gotten alittle better but it's still smoking which is kinda bugging me. Anyone has any tricks or comments on what the problem could be or has ever had this problem before. Lmk thanks
I been doing 2, 3 gear pulls, goin up hills to put load on the rings, stayin less than 55 mph and stayin under 5500 rpm so far.. I kinda been doin hard acceleations butthats about it.. Changed the oil after 20 mins after initial start up.
the machine shop did all the bottom end work so I am assuming he did everything correctly. the machine shop has a good reputation and I believe he did the job correctly. But, I know that people make mistakes even pros so Ill jus have to wait and see if the smoke clears within 500 miles. If not Im sure I'll have to rip this motor apart again....SMH
Broke mine in on the dyno, first pull I filled the entire shop with blue/black/white smoke scared the **** outta me. But after a few more pulls zero smoke, sounds like it's still working its way. Try giving hard acceleration and lift off while in gear to let the rings expand outwards on all gears.
UPDATE: just finish doing a leak down test here are my results
Cylinder 1: 10%
cylinder 2: 17%
cylinder 3: 12%
cylinder 4: 9%
Are these bad numbers?? Keep in mind this motor was Honed, installed new rings and bearings, and valve seals. Motor has about 130 miles so far and nit fully broken into yet..
Cylinder 1: 10%
cylinder 2: 17%
cylinder 3: 12%
cylinder 4: 9%
prettylew
45
Dec 16, 2007 06:48 PM
kidd_drastic
Jul 20, 2006 04:12 PM
Ri5e
Jul 30, 2002 12:02 PM
