4-Wire oxygen sensor
Old Sep 11, 2011 | 02:02 PM
DRatedA.W.D.'s Avatar
Default 4-Wire oxygen sensor
I'm cleaning up wires and jumper harness wires after previous owner did the mini-me swap but didn't finish completly. Jumper harness, o2 sensor and 3 left over wires not wired into anything.
Now my question is, the o2 sensor has 4 wires. Can anyone tell me how these wires are wired? Thanks.
Old Sep 11, 2011 | 05:15 PM
zrickety's Avatar
Default Re: 4-Wire oxygen sensor
2 heater wires, 1 signal wire, 1 ground. what colors do you have?
Old Sep 11, 2011 | 05:22 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
The factory wiring is as follows:
White = O2 Signal (D14)
Green/White = O2 Ground (D22 or similar logic ground)
Orange/Black = O2 Heater (A6)
Yellow/Black = O2 Power (A25 or switched +12v source)
Old Sep 12, 2011 | 10:58 AM
I got white, green/white, and 2 blacks. Does it matter which black wire gets wired to heater and power?
Old Sep 12, 2011 | 12:27 PM
DO IT ON ALL FOURS
Aftermarket wiring is as follows:
Green = O2 Ground (D22 or similar logic ground)
Obviously it matters - if you get an O2 heater code switch the two black wires around - simple as that.
Old Sep 17, 2011 | 04:51 PM
Magnolialabell's Avatar
I have a 2001 Honda CR-V. My brother pulled off the oxygen sensor without looking to see which wires matched. Love him but Arrrrr! My Honda wires are candy-striped as (1) green/black, (2) yellow/black, (3)white/black, and (4) solid white. I have a Bosch Universal Oxygen Sensor and it has 2 white wires (Heater), one gray wire and one black wire. I would deeply appreciate it if someone could tell me which wire matched to what.
Old Sep 17, 2011 | 05:23 PM
You sure you're posting in the right forum for that question?
Old Sep 2, 2015 | 07:01 PM
Gerardomx's Avatar
Bosch Universal Oxygen Sensor.- 2 white wires (Heater & power), one gray wire (ground) and one black wire (signal).
So the you might connect the gray and black first. Start the car and look for AF lamba signal. if ok, now connect one white to one black....and check if you have check engine light?, if not (ok), connect the last white to the last black. If not ok, swap to blacks. good look.
Old Sep 2, 2015 | 08:25 PM
Former User's Avatar
Old thread locked.
Tomina
Oct 14, 2014 11:04 AM
91efbluehatch
13
Nov 7, 2012 06:21 AM
underdog51
Nov 25, 2005 12:09 PM
V3locity
Jul 26, 2004 06:54 AM
HXMan
Apr 26, 2002 08:13 AM
