Car starts everytime but won't stay on!
Old Sep 11, 2011 | 10:06 AM
TuwboBuddy's Avatar
Default Car starts everytime but won't stay on!
Just finished a head gasket job on my car and now the car will start but will not stay on for long. If I keep revving it up it will stay on, I tried driving it down the block just to see how it drove and it was jerking like crazy when I gave it any gas....also I have not been able to find my map sensor plug but I dont think it was plugged in to begin with...
Old Sep 11, 2011 | 11:05 AM
fcm's Avatar
fcm
Old Fart
Default Re: Car starts everytime but won't stay on!
Check for vacuum leak, make sure all the vacuum lines are plugged in properly.
Check your valve timing, do not run engine untill you have confirmed valve timing is correct. 94
Old Sep 11, 2011 | 11:19 AM
jdmasfck95's Avatar
I have just done a headgasket on my 95 integra and it really sounds like your timing is off when you give it gas it probley dont have the reaction it normally does and does not rev up real hard if thats the case just check your timing and if you still think think you have a vac leak just sprat some WD40 around on your hoses if it dies down you gotta vac leak.
Old Sep 11, 2011 | 08:47 PM
TuwboBuddy's Avatar
No vac leaks...but I will double check. I also set the motor to TDC and reset the cam timing a second time to be sure. Could it be I'm off a tooth? Or could it be that my MAP sensor is not plugged in? If I'm not actually driving it, the car does rev up fine but there is a slight squeeling here and there....
Old Sep 11, 2011 | 10:48 PM
Lsvsmoker's Avatar
Sounds to me is the map sensor, check for codes I'm almost 100% it's the map cause my car did the same exact thing and when I changed the map it ran like a champ
Old Sep 12, 2011 | 12:31 PM
TuwboBuddy's Avatar
Well...yes it is throwing the map sensor code...but if it was the timing it wouldn't throw a code..
Old Sep 13, 2011 | 09:21 AM
TuwboBuddy's Avatar
bump
Ran4it2
Jun 11, 2009 11:46 PM
DBAl
Jun 4, 2007 06:54 PM
Got Snail 2
May 22, 2007 03:53 AM
1987CRXSi
Dec 29, 2004 07:12 AM
tteg94
Jul 9, 2004 01:10 PM
