need a little help
Old Sep 10, 2011 | 09:18 PM
cristegra09's Avatar
Default need a little help
good morning guys, im sure these topics has been covered plenty of times so just bare with me.
1st- I bought this gsr engine from local junkyard a yr ago
and need to know if theres.anything I can do to check of valves and pistons other then crankin it by hand.tryin to avoid takimg the engine apart.
2nd- when I get the.engine checked and.ready to connect.with.tranny,is there a.certain way im supposed to set the tranny b4 installing.
thanks for ur time. write back asap!
Old Sep 10, 2011 | 10:21 PM
Hidenplanvew's Avatar
Default Re: need a little help
You could use a scope with a cam on it... That way you can see all the walls and top of pistons.. Next would be a leak down test.. Putting on a trans is pretty forward.. Just line up the input shaft and slide it together.
Old Sep 10, 2011 | 10:45 PM
thanks and im sure the engine is good just wouldnt.hurt to.recheck.this.would b my 2nd swap n 5yrs im a little rusted. any way u can send me.ur contact info just.ncase I.get stuck
SedanTuner
Feb 6, 2012 08:55 PM
Paperboy177
Sep 14, 2010 05:11 PM
SSBPGSR
Mar 28, 2005 12:52 PM
dohcguy
Feb 3, 2005 10:29 PM
Phoenix1
Mar 4, 2003 05:00 PM
