ordered the wrong cometic gasket! is it going to be a problem?
Ordered a 81.5mm gasket when the bore is actually 82. I went cross eyed when placing my order and switched the part numbers. Will the 81.5 cause a problem on a 82.
I was told you can do this. correct me if im wrong.
Whats the downfalls do doing this rather than buying a new gasket. Thanks for your time.
i think oem headgaskets are 82mm so if u go with oversized pistons u can buy the same size..so that shouldnt be a problem..
BlackGSR
Feb 26, 2002 06:52 AM
