Battery keeps dying!
Old Sep 9, 2011 | 02:48 AM
bigsnorlax's Avatar
Icon2 Battery keeps dying!
For the past couple of weeks when i return to my car after its been sitting for a while and turn the key the engine will not turn over. I would try a couple times and it would just barely get enough umph and turn over and start. So i used a battery tester and got weak readings and this battery has been in there for almost ten years so i figured it was time to replace it.
Went to walmart 2 days ago and swapped out for a brand new one that worked great for the first day!... and now its doing it again. I know its not the alternator because if i let it run for awhile it will start next time easily, but if i do a very short errand it does it. Also i pulled the negative terminal while the car was running and the stays running perfectly, not even a falter.
Im not really sure what to check at this point, obviously SOMETHING seems to be putting a load on it while the car is off and draining it. What could drain a battery like that? I do have two 12'' subs and an amp, but iv since disconnected them when the old battery was acting weird and it still is disconnected.... Can a bad ground do something like this?
Old Sep 9, 2011 | 03:21 AM
hondamark35's Avatar
Default Re: Battery keeps dying!
some parasitic draw while the car is off i guess.
testing is pretty easy, just a little bit tedious. it helps to have your wiring diagram handy. you'll also need a multimeter.
set it to look for amperage draw (...if memory serves, it's been a while since i had to do this). with the key off (or out) check amps at each fuse socket making note of the readings on each. there should be a pretty small draw for the ECU memory and the stereo memory. otherwise there should be nothing. try leaving the fuse out on any circuit showing a draw and then reinstalling them a few days later when you try to start the car again. see if that gets any results.
Old Sep 9, 2011 | 04:48 AM
bigsnorlax's Avatar
Thanks for the idea. I guess i'll have to try something like that... and ill need a multimeter ha.
It just strikes me as odd how this suddenly happens.... and the only explanation i can think of is some sort of "parasitic draw," as you stated.
Would a bad ground cause anything like this? Im not too good with electronics/current But thats what all my friends tell me to check but i dont think that would DRAIN a battery. But if it was a ground... it just wouldnt be starting... or would shut off randomly right? (sister's crv did this untill we found the loose ground on valve cover)
Old Sep 10, 2011 | 04:47 AM
Lost Again's Avatar
Try reading this for help.
flashoffroad.com/electrical/Batteries/BatteryDrain.html
Yellowone
Sep 1, 2011 07:50 PM
old-sk0ol
Nov 26, 2008 09:57 AM
Thrillhouse
Jan 30, 2003 01:47 PM
ViZ
Audio / Security / Video
Jan 22, 2003 07:45 PM
ViZ
Jan 22, 2003 08:56 AM
