all motor prob
Old Sep 8, 2011 | 10:14 AM
gerbsgsr's Avatar
Default all motor prob
hey guys and gals i having a prob with my all motor. At idle my car runs amazing but it is rich, when i start to drive it down the road it starts to dog out and acts like it is running on two cylinders and leans out so much it wont read on the wideband, i have changed the fuel filter, checked the fuel pump and now cleaned out the fuel rail. i have also changed the plug wires and plugs. What do you think i can check before i take it back to the dyno and spend more money?
Old Sep 8, 2011 | 10:54 AM
95 integra's Avatar
Default Re: all motor prob
O2 sensor? Pull the ECU, pull the chip, reinstall. Take it back to your tuner and tell them they jacked it up and they need to make it right?
Old Sep 8, 2011 | 11:08 AM
gerbsgsr's Avatar
i had the O2 sensor cleared out of the tune cuz it didnt work so thats where i got my wideband pluged in now, what will pulling the chip out and reinstalling it do? and i called the guy that tuned it and he said he would fix it but i would still have to pay for his time wotking on it cuz he said it is very rare that something in the tune went bad
Old Sep 8, 2011 | 11:45 AM
wreckeddc4's Avatar
Is everything still setup to where you can check trouble codes and check engine lights? Try that. Most bad sensors will throw a code.
Consider that ait, map, tps, o2 all affect a/f ratio so it's possible one went bad. And even though you possibly ruled out the o2 there's a chance the ecu can still be looking for it.
Old Sep 8, 2011 | 12:05 PM
GhostAccord's Avatar
Have you changed anything since the tune?
Old Sep 8, 2011 | 01:17 PM
95 integra's Avatar
On my old prelude, when I turned the O2 sensor off, it would do something very similar. Pulling the ecu/chip would clear it up for about 2 weeks...never could figure out why. Turning your O2 feedback off is never a good idea though, just results in bad fuel economy and less driveability from what I've seen.
Old Sep 8, 2011 | 01:19 PM
CHEETAH's Avatar
simple checks, are any of the header primaries colder than the others? pour couple drops of water on each primary...to identify if there is a dead cylinder
clogged injector could also be problem...
Old Sep 9, 2011 | 02:07 PM
gerbsgsr's Avatar
the only way i know how to check the codes would be to jump the harness but i have no check engine lights on, thank you ill try that
Old Sep 9, 2011 | 02:10 PM
gerbsgsr's Avatar
the only thing i have changed since the tune would be fuel filter, plugs and wires and i didnt do anything till it started screwing up
Old Sep 9, 2011 | 02:12 PM
gerbsgsr's Avatar
just cleaned the injectors last night and cleaned the fuel rail, and it ran a little better but was still screwing up pretty bad, and i pretty sure i dont have a dead cylinder but ill check those to thank you
Old Sep 11, 2011 | 07:21 AM
xzodiackillerx's Avatar
pull your plugs and see what they have to tell you.
Old Sep 11, 2011 | 09:08 AM
gerbsgsr's Avatar
they are brand new plugs
Old Sep 11, 2011 | 10:52 AM
DDTECH's Avatar
that doesn't matter.. pull your plugs and look at them.
Old Sep 11, 2011 | 02:42 PM
gerbsgsr's Avatar
i pulled the ecu today and took the chip out and i tried that and now i cant even get it to idle or run for a min. any other ideas you got that i can try
Old Sep 11, 2011 | 02:49 PM
00Red_SiR's Avatar
All Motor Mentor
how do the plugs look? did any of the prongs on the chip bend or break off when removing/reinstalling it?
Old Sep 12, 2011 | 02:47 PM
gerbsgsr's Avatar
no none of the prongs bent or broke off i checked all that, and i didnt check the plugs
Old Sep 12, 2011 | 07:07 PM
DartGuy25's Avatar
New ecu!
Old Sep 13, 2011 | 06:29 PM
gerbsgsr's Avatar
could it still be something in the dizzy or would it be like a map sensor or a throttle position sensor, bad chip or bad ecu i kinda at a loss right now and i dont know what to really look for anymore try a different throttle position sensor and thinking about trying a different dizzy
Old Sep 14, 2011 | 03:55 PM
gerbsgsr's Avatar
ok i checked the plugs they are still good very little white on them but thats all
Old Sep 14, 2011 | 04:01 PM
negusjuda's Avatar
map and tps should throw a code if there is a issue
Old Sep 14, 2011 | 04:02 PM
negusjuda's Avatar
and i have heard of chips going bad it is a electrical component
Old Sep 15, 2011 | 02:45 PM
gerbsgsr's Avatar
its not map or tps i have no code and i checked all of those last night just to be safe
Old Sep 15, 2011 | 02:46 PM
gerbsgsr's Avatar
component
that basically what we are down to now its either in my chip or my ecu
EFb18b
Aug 2, 2015 04:28 PM
Toadfart
Oct 11, 2009 05:54 PM
FROSTDC2
33
Oct 23, 2005 01:31 PM
2000CX
Aug 14, 2003 05:15 PM
