WHAT INJECTER SHOULD I PUT ??
how about looking at others builds and check their power level and see what they use..
and for 300whp on a stock D, injector sizing is going to be the last of your worries!
better start looking at building the bottom end. pay attention to the oil pump!
I would get a set of 750s and for the oil pump you need to port and/or shim it to improve oil pressure.
Now here's the thing. How do you know what I just told you is accurate?
What are your plans for engine management? Fuel pump? Clutch?
I have to say you aren't searching whatsoever. I have told you at least TWICE to compare other builds and make note of what they are using. If you keep this up your whole build will be one monumental FAIL. And please don't tell me you're learning. This is not a subject you want to learn as you go unless you can afford to keep replacing engines and parts.
Every post I see recently has these types of questions. Everyone wants other people to tell them what to buy/do with their cars. If one would stop to look around and research they wouldn't have to post stupid questions on a tech forum and expect an answer right away.
I love the F.A.Q. we have here. I have been working with Hondas for 8 years now and I still use that as my first outlet for info, for god's sake it's a sticky.
And this post belongs in the forced induction section anyway.
Good luck with the build, I mean it. But please, do a little searching on your own and in no time you'll be answering other peoples questions and helping them out.
I now see why you are so short with people.
This whole board is 60% noobs who want to be spoon fed the info when the info is all over the internet.
HP
read the stickies at the top of the forum.. they are stickied there for a reason. Alot of good info.
read this also.. its outdated but has great info for the noobs.
http://www.beesandgoats.com/boostfaq/g2icturbo.html
fail.
Have fun replaceing that peice of **** clutch in a few months when it fails.
We can spoon feed you boost, BUT, it's going to end badly. You NEED to search and figure this stuff out yourself.
I bet, you still have no clue what ECU your going go run, turbo kit, exhuast, are you going to do any cooling system upgrades?
Are you going to do anything to the head? Have you even talked to any shops, who's going to tune the car?
when guys say search they mean get a rough idea from another combo. you can come back and say...hey guys i was looking at a garrett 50 trim and precision 5431e, what's the difference? something like that you'll get help with but entire builds make us bang our head in the wall since you're asking too large of a question and not putting any effort into finding out how to start.
NeXtLeVeL_TyPe_R
Jun 1, 2002 05:18 AM
