Suspension & Brakes Theory, alignment, spring rates....
Car pulls all over the place, like a really bad torque steer
Old Sep 6, 2011 | 01:28 PM
$amGD3's Avatar
Swaggylicious
Default Car pulls all over the place, like a really bad torque steer
Hey everyone, so my car has been pulling it self all over the road and it's starting to get worse and worse. When I make a right turn, the car turns left by it self. I'm thinking it's my tie rods?
When I bought the car 3 years ago, both inner boots were torn and grease has been everywhere for a while now.
Maybe?
What parts do I need to replace these? Do the inner tie rods come with boots?Should I get inner and outer??
Old Sep 6, 2011 | 06:16 PM
pwebb0207's Avatar
Default Re: Car pulls all over the place, like a really bad torque steer
matching front tires?
Old Sep 6, 2011 | 06:24 PM
$amGD3's Avatar
Swaggylicious
yep, similar tread life. Oh and something "clicks" when i make a sharp right turn
Old Sep 6, 2011 | 06:32 PM
BoosterB16's Avatar
sounds like your axle is bad if there is a clicking sound
Old Sep 6, 2011 | 07:27 PM
$amGD3's Avatar
Swaggylicious
all the time matt
Old Sep 6, 2011 | 10:04 PM
chiprez's Avatar
Excessive toe out causes wandering. If your inner tie rod boots are indeed torn, then your steering rack is internally leaking. Clicking while driving would be bad axles.
Old Sep 7, 2011 | 07:23 AM
$amGD3's Avatar
Swaggylicious
What do you mean by internally leaking? Will replacing the inner tie rod + boot + outer tie rod remedy the situation?
Old Sep 9, 2011 | 02:30 AM
google123's Avatar
10 Year Member
I would replace inner and outer tie rods, go for an alignment to correct toe specs and then replace those CV axle(s) to eliminate clicking noise during turn.
Old Sep 9, 2011 | 07:17 AM
AK94GSR's Avatar
Start with an alignment. if your toe is out of wack then your vehicle will follow every groove in the road
Northernlightz
Apr 2, 2015 07:15 PM
Vagitarian
Jun 3, 2012 09:46 AM
wc4ohio
Apr 13, 2011 06:51 AM
phongadong
May 7, 2008 09:12 PM
94eh2
Feb 14, 2007 04:52 AM
