cv joints?
cv joints?
ok i have a eg hatch ..since i bought it i was told i had bad cv joints but never changed them..now when i drive my car it hops..if i go under 20 mph the front wheels start hopping and chirpin and my steering go crazy the same happensif i go over 40mph..and when i turn same thing..what could this be ? bad cv joint?
Re: cv joints? (305accord)
those and possibly your allignment, the easyiest way to also check your alligment is to remove the front tires and jack up the car, wiggle both the left and right side steering assembly and if it seems loose take it in for an alligment check, but if someone told you your cv shafts are bad, more than likely there correct and also replace them if it continues after an alligment is done, tie rods may also be bad
Re: cv joints? (Projekt_2nr)
well i kno for sure i need an alignment but it cant be that because ive needed and alignment since i bought the car and it was fine..and i have had the passenger side tie rod replaced already..
my bro's civic did the same thing, it was an alligment issue, after he took it in and did an alligment it never did it again, does it pull to any certain direction while driving?
$amGD3
Suspension & Brakes
09-09-2011 07:17 AM
