Fair warning on IR compressor
Old Sep 6, 2011 | 10:17 AM
90blackcrx's Avatar
Default Fair warning on IR compressor
I'm not starting this thread to start a bickering match, I have a few other IR tools and love them but after this incident, I most likely will never support IR again. This is just a warning for people looking into this compressor or maybe something similar.
I bought a 60 gallon IR compressor 3 years ago, since then I've replaced the switch because it would stick ( normal wear item, not a huge deal ) . And Sunday night I flicked on the compressor and the motor literally went up in flames. Probably would of burn the shop down if I wasn't there to stop it.
After doing some research, its a common problem with the motor and it seems like IR knows about it yet won't do anything. A new motor from IR is $417 ish dollars, and I called granger and they wanted $918 dollars. I paid $919 for everything, so I'm still looking around on my options.
Here is another link with the same issue
http://www.hotrodders.com/forum/comp...=1#post1465877
Here is the actual pump
http://www.google.com/url?q=http://w...ed=0CCMQqxIwAA
Old Sep 6, 2011 | 10:46 AM
racebum's Avatar
Default Re: Fair warning on IR compressor
sorry to hear it. oddly enough the husky and campell 60s are popular around here. they cost less and have been proven to be reliable. my dad bought a 500-600 60 gal campell back in the late 90s that's had nothing but oil changes to this date.
Old Sep 6, 2011 | 10:51 AM
CRMB's Avatar
OG Fabricator
I would dump that garbage motor they use and pickup a Baldor TEFC to replace it with - and never worry about it again.
We replaced the motor on our huge IR 30HP 3000T compressor about 8 years ago with a baldor motor and have never had a single day down since. The original motor went up in smoke.
Old Sep 6, 2011 | 11:03 AM
90blackcrx's Avatar
Do you have any suggestions on where to pick one up at ? I would need to call them to see which one would work out for what I need.
Old Sep 6, 2011 | 12:35 PM
CRMB's Avatar
OG Fabricator
Bob if you cross reference your hp, phase & frame type on baldor's website. Get a motor # then plug that into google or ebay see what you can find.
If you are lucky - you will be able to find a new/old stock for a fraction of new. You just want to make sure that the mounting & physical dimensions will work. The different series they have are related to duty cycle, but we run almost exclusively super-e tefc motors.
Old Sep 7, 2011 | 07:26 AM
90blackcrx's Avatar
I found everything on the motor besides the enclosure type, any ideas of what it would be or where I could find it ?
This is what I have it narrowed down to, when I left the enclosure to all.
http://www.baldor.com/products/produ...00&voltage=230
Old Sep 7, 2011 | 02:30 PM
CRMB's Avatar
OG Fabricator
Bob take a picture of the motor and measure the center to center of the mounts and the shaft diameter. Then give baldor a call and give them those measurements and any pictures you took. They should be able to get you close enough to match it up.
Old Sep 9, 2011 | 06:06 PM
therealpoorboy's Avatar
That sounds just like an Emerson. I work for them and I stay as far away from any of the electrical or any of the EPT products as humanly possible.
Old Sep 13, 2011 | 04:46 AM
19civic93's Avatar
Don't bother with those single stage compressors. They try to get max cfm out of them and the motor overloads. Get a 2 stage compressor. I've had my 60 gallon IR for 10 years now with no problems. It's rated at 15 cfm at 175 psi. All I do is change the oil and air filter when needed and it's been very good to me. I use it for mostly body and paint so there's a lot of hours on it and it's still going strong.
Old Sep 16, 2011 | 07:09 AM
90blackcrx's Avatar
Well my neighbor had an account with someone that sold baldor so I was able to get a new motor for around the same price IR wanted, which was $430. When I looked at baldor's site all the prices were around a grand so I'm pretty happy.
Old Sep 16, 2011 | 08:14 AM
90blackcrx's Avatar
Actually its not a Baldor, its an AO Smith motor. Does anyone have any feedback about their products?
Old Sep 16, 2011 | 12:06 PM
vtecnitrocrx's Avatar
I have two 80 gallon IR 2 stagers (15.5cfm at 90-175psi). One is in my shop and runs 12hrs/day 6 days/wk and one at my house for random use. I can't say a bad thing about them and haven't had the first problem. Maintenance goes a long way I think on these, but that's about it.
Old Sep 16, 2011 | 04:57 PM
90blackcrx's Avatar
What motors on them?
Old Sep 16, 2011 | 05:22 PM
SLMachine's Avatar
OG Fabricator
Same here.
7.5hp motor.
Old Sep 19, 2011 | 06:46 PM
90blackcrx's Avatar
Yeah that's not the motor they have issues with.
Old Sep 29, 2011 | 07:36 AM
mkehler's Avatar
I could have written the original post myself..same deal. Local rep didn't really seem to care. talked to the territory manager, he seemed to care, and said he would call me back. didn't hear back, so i called him again. said he would call back. never heard back. I just bought a AO Smith myself. I'll never buy another IR product again, mostly due to the fact that their reps don't seem to care. In western canada at least.
btw mine is the IR2340 5hp 2stage with the Emerson motor
Old Sep 29, 2011 | 04:17 PM
c5R's Avatar
c5R
my 5hp IR compressor went up in smoke 4mo after i bought it
Old Oct 4, 2011 | 02:35 AM
Boosted_B_Series's Avatar
Damn, I have two 60-80 gallon compressors with emerson motors.. Ones a IR.. Both almost new.
choua01
Mar 18, 2009 08:03 AM
89efDUSTY
Nov 21, 2008 11:42 AM
tony413
Paint and Body
17
Oct 13, 2008 08:20 AM
97civic123
May 27, 2006 05:50 PM
